Heater valve stuck closed
My Ride: '10 535i, '08 X5 3.0, '00 528i, '98 M3
Model Year: 2010
You need to have the car scanned for error codes. Install INPA on a laptop or buy Carly for an iPhone/Android.
DIY: How to setup BMW Standard Tools 2.12 w/Windows 7 x86 (32-bit)
Bmwhat app (Carly for BMW)
My Ride: 2008 528i Premium with coded options
Assuming the E60 works like earlier 5 series, you give up automatic control of temp when you disconnect the heater valve, because the heater valve is fully open all the time. The blue-red adjustment only affects the center vents. The floor / defrost vents are likely hot all of the time.
Heating / AC:
Air conditioning / Klimaanlage
Fault: Monitor sun sensor supply
Code: 9C6D
Fault: Monitor Fondpotiversorgung
Code: 9C6E
Fault: Error fogging sensor - K-LIN 3 RLS
Code: 9C55
Now, in think it's important to mention that I did doing a little bit of codingnwith Carly for BMW right before the problem started.
If I reflash the IHKA back to default with ncsexpert, could that solve the problem? And I have already replaced the rain/light/solar sensor. No difference.
Model Year: 2010
You should start by undoing everything you did w/Carly. I believe you can do this w/Carly. Did Carly re-code the IHKA module? Which modules did Carly re-code? What coding were you attempting w/Carly?
I coding in the LMA and IHKA (display orange light on fan dial when in auto).
If I reflash to default, is should fix anything that could have gotten corrupted, correct?
Model Year: 2010
Default coding should do no harm unless you or Carly have changed the VO. Only code the affected modules. I would not code the entire car.
After a little more thinking and retracing my steps, I realized I messed up with restoring defaults.
I did not restore the IHKA on both the CAS and LMA modules.
The fix:
Use a default restoration profile on NCSExpert.
Apply default IHKA settings to CAS. Exit, then do the same to the LMA module.
This fixes a heater valve that is functional, but stay closed due to a bad signal from the climate control unit.
The fix:
