Headlights on in daylight - SOLVED!
This may be an old topic, so excuse me if this is old news.
I couldn't figure out why my headlights always came on when the dash switch was set to "A" for automatic. Even in bright sunlight the headlights would come on despite what "wert" I set the light sensor to in coding. I was forced to keep the headlight switch to off and turn them on manually.
I was fooling around in the iDrive and under the Vehicle/Settings, I unchecked the Daytime Running Lights box, and viola, the headlights turned off!
I thought this box was for the inboard running lights, but it was for using the headlights as DRLs.
So now I can leave the headlight switch to Automatic and not look like a dork in the middle of the day!
![Cool](https://5series.net/forums/images/smilies/imported/cool.gif)
Jay, you are correct. I thought it would control the inner lights, not the main headlights.
I also added an option for the adaptive headlights to go from Comfort - Sport- Off, but when I try to change it from Comfort to Sport, it just goes back to Comfort. I'm pre-LCI, so I don't have the correct hardware or modules.
I run my headlights "ON" all the time rather than AUTO, for safety you know. I couldn't give a rip what anybody might think of me.
Part of the reason is I park in a heated garage (luxury, yeah) and with the switch in AUTO the lights come on for a few seconds then turn off as I reverse into the daylight. Wear and tear issue too.
