Hi All-
I've been searching and searching for something on this topic. Forgive me if this has been beaten to death. I've got an '04 530i. The little green LED light next to the selector switch for the headlights is blinking. I know that it indicates a malfunction. When starting the car, in adaptive mode (auto), the headlights will do their up and down but most of the time the Passenger side will then point down and to the right (away). If it actually does point straight ahead (about 40% of the time) the headlights do not move while driving. If I turn the headlights on manually, it may point down too, that is hard to confirm because I have to wait until it returns to the normal position. Does anyone have a solution? Thank you in advance! |
Sorry I can't help you. However, your issue has been brought up before and the general census is that you have to take it to the dealer (or independent) to get repaired. Either the motor is out or just needs recalibrating or both.
Originally Posted by Leatherneck1
(Post 1431043)
Hi All-
| All times are GMT -8. The time now is 06:33 AM. |
