headlamp H3 problem
Can any one help me with my problem please???
My BMW E60 520d 2008 UK model, have xenon on low beam and hi beam.
I use H8 for angel ayes and in front of it I have a smole h3 lamp - that I observe is working sometimes only one side for few second and then.. finish... I have to restart the engine to see it again..
can you help me with this?? is possible to be the LKM - light Kontrol Module?? where is that .. and what shall I do..
Thanks.
Thanks.
My Ride: BMW E60
Model Year: 2016
You're referring to the corner light? The small inner bulb. It only comes on when you put your car in reverse, and also the matching side when you're turning at slow speed.
1 - turning signal
2 - low and hi beam - I think is bi xenon
3 - a place where I sow only few times on .. but now I can not see it ... in same place I put 2 bulbs - H8-for the angel and H3 wich sopose to see it in front of the car
my problem is with #3 H3 and not H8.
The angel eyes is fine
I've put today my wife to put in reverse.. but it not comming on at all. No error on dash board or Idrive
any other sugestion??
please
My Ride: 545i sport
I am not really sure which lamp you are talking about, but i noticed when replacing the angel eye lamp in one of the headlights on my car that the heat from the lamps had caused the wiring insulation to become brittle and flake off. I had to carefully apply electrical tape to ensure the wires would not touch each other and short out. Maybe that is what has happened to your headlight assembly and the LKM is turning the lamp off as a safety precaution against a short circuit. I would think you would get a lamp out warning in cluster.
My Ride: BMW E60
Model Year: 2016
Yah, you're going to have to get the dealer to replace the cornering light's bulb unless you want to cut open your headlights. I don't really see how it's possible replacing the bulb without taking the headlights apart.
About the h3 bulb, on the headlamp is a smole round black cover on top of the headlamp that you hace to turn it just 1cm an under it you will see the h3 bulb. You have to press down the metal thing that cover the bulb and also it fix it to stay fix and not to move... just press it down and move it a litle bit forword... and it will come up. just take the h3 wire - DO NOT TOUCH THE BULB - and drag it out... and same way you can put a new bulb there...
my problem is that I can not see the h3 working... when it have to work?? I wish to see it working...
Thanks
Andrew
My Ride: BMW E60
Model Year: 2016
is not the bulb.. and is verry easy to replace the bulb.. you do not have to take the headlamp down... for this.. to replace the H8 (the light for the angel eyes)is a round black cover that you have to turn it like a screw, and is open.
Thanks
Andrew
Thanks
Andrew
Ahh! So that's what that hole is for? All this time I have always wondered when I worked on the headlights. Now that makes sense, lol. From what you said in your first post, it's working as it should -- refer to post #2.
So.. when the inner lamp will be on??? he H3???
Thanks
Andrew
Today, I've been to close to other car and I turn right hard. when I turn right I saw that the right inner lamp - that is with h3 it come on...
again.. I've put my wife at home to turn the wheel and I saw that they are working...
Soo... is done.. no problem at all... but I wish to have them allwise on if possible... but that's it.
Thanks for your advice..
and by the way.. do you know any posibility to open the headlamp??
wish to clean it inside.. but it have some sort of silicone at the edge and I can not see any way to open it... any advice??
thaks
