Having trouble
Old Dec 11, 2008 | 05:28 PM
E60525's Avatar
Hey guys,
my 2004 525i with only 34k miles on it is acting up a little bit. Everything mechanical is good, knock on wood but my stereo is messed up. When i play the radio and cd's, the music goes away and a loud static noise comes from the speakers. This happens on and off and is most annoying. Has anyone else experienced this and can give some insight on what the actual problem is?
Old Dec 11, 2008 | 05:30 PM
nigxdoof's Avatar
Originally Posted by E60525' post='743441' date='Dec 11 2008, 09:28 PM
Hey guys,
I had something similar with my radio, but it just cut off and came back on once in a while, and didn't have static. It turns out the alternator was going bad and since i replaced it, its back to normal. It could be that. Does your car have extended warranty? if so, ask the dealer to check your alternator and see if it needs to be replaced.
Good luck.
Old Dec 11, 2008 | 05:53 PM
E60525's Avatar
Also on cold starts, it sounds really bad when i turn over the engine. It almost sounded like something is getting scrapped
Old Dec 11, 2008 | 06:02 PM
nigxdoof's Avatar
I had that a few times too.. definitely look into the alternator.
Old Dec 12, 2008 | 08:06 AM
porsche911targa's Avatar
Yup, sounds like an alternator. I've had the same symptoms on other cars and they all resulted in alternator replacement.
Johnny B
E34/E28/E12 Discussion
Dec 25, 2015 05:33 AM
Henry Peters
Sep 25, 2015 10:15 AM
Island Road
Sep 12, 2015 06:47 AM
hmilycar
Sep 10, 2015 12:32 AM
SDALEX
Aug 17, 2015 04:10 PM
