Having problems removing front strut
Old Mar 25, 2015 | 03:00 PM
535DREAMER's Avatar
My Ride: e60 535xi Prem. Package
Model Year: 2008 535xi
Default Having problems removing front strut
Iam trying to remove my front strut of my 535xi. All bolts are out. Its just to get the strut out of the bottom part that is connected to the axle (i dont know the name of it).
Any ideas ?
Old Mar 25, 2015 | 03:22 PM
pcy's Avatar
pcy
Looks like you already removed that long bolt that holds the collar around that strut.
Take a cold chisel or some similar tool and 'spread' that collar where you removed that bolt.
Old Mar 25, 2015 | 03:38 PM
KyleB's Avatar
My Ride: 530i
Engine: M54
you need to use a steering knuckle spreader, or something that will act as a spreader, and open the retaining collar on the knuckle. I'd also shoot some WD40 in there too to loosen things up.
Old Mar 25, 2015 | 04:04 PM
535DREAMER's Avatar
OK will try this and report back
Old Mar 25, 2015 | 04:17 PM
quanger's Avatar
My Ride: 530Xi
I used a 1/2 to 3/8 socket adapter, a short stubby one. Insert the 3/8 end in the gap, use the 1/2 breaker bar turn the adapter slowly (like a quarter turn) till the diagonal of the 3/8 end spread it wide enough to get the strut out. Hope the picture help. Good luck.
Attached Thumbnails Having problems removing front strut-untitled.jpg   Having problems removing front strut-8556300.jpg
Old Mar 26, 2015 | 07:37 AM
535DREAMER's Avatar
Ok got the strut loose in the knuckle now when i pull up to take the strut out it can't. I already loosened the tie rod and endlink. Is there something else i need to loosen or take off to get the strut out ?
Old Mar 26, 2015 | 09:11 AM
jamo.w's Avatar
My Ride: 2008 BMW 535xi
This is a great tutorial, it's what I used to guide me throught the install.
BMW 5-Series 530i E60 (2003-2010) - Replacing the Front Shocks - Pelican Parts Technical Article
Old Mar 26, 2015 | 04:52 PM
pcy's Avatar
pcy
Did you remove the nuts on the top of the strut?
Old Mar 26, 2015 | 05:25 PM
535DREAMER's Avatar
NOPE! But I did now and got it out. Thanks guys for all the help. Now to install my CKS Coilovers
Old Mar 31, 2015 | 03:13 AM
s2k_john's Avatar
My Ride: 535i
How you liking the CKS coilovers?
Awest91
Sep 17, 2022 11:05 PM
boyhamdzui
Apr 14, 2015 04:47 PM
Sibby1979
Mar 24, 2015 07:12 PM
RichReg
Jun 20, 2003 06:29 AM
