have some issue with 545i 6 speed
My Ride: 2005 E60 545i Manual, Sport, L7
Model Year: 2005
I try to describe my issue as much as I can to you so you can help me to diagnose it. when the car is cold and driving on low speed in first 3 gears i starting feel slight hesitation or slemming or jerking. when i am in gear and release from gas pedal and push it again to gain speed car hesitates for second and starts jerkong kind motion than i have to downshift to get it moving. i am driving this car for 3 years now and never had this problem. once the engine gets warmer and on highway speeds it drives beasty. car is on 119k miles. all fluids replaced friquently. is here anyone with same problem and your opinoin what the coase could be?
thx
thx
Might want to check out this post:
Bimmerfest - BMW Forums - View Single Post - DISA Failure!!!.... (545/N62)
My Ride: 2006 550i, 6 speed manual
My 06 550i was exhibiting similar behavior. Put in 2 cans of BG44k fuel system treatment and had the dealer download the latest ECM updates. Currently at 89k miles, no problems since.
Model Year: 2005
thanks
Mine was done under extended warranty in conjunction with resolving an active steering malfunction. I recall that the cost for a dealer to perform a complete ECM software update is in the vicinity of $400 and suspect that an Indy can do it if they have the right equipment.
My Ride: '04 545i
Model Year: 2005
yesterday.while driving i got check engine off. car was on misfire like missing one or two cylinders
checked the codes on INPA and got these 2E24, 29CC, 29CD. which is misfire on cylinder 1, ignition sequence. relocated the coils on cylinder 1 and 2 but same codes. is this bad coil or wiring. i am going to replace all coils same time which was in my list anyway but want to know if i need new wiring also to order it same time. can the wire be bad? how hard it is to replace the wire?
Thx
Thx
Model Year: 2005
i drove it for few miles than turnd off and restarted. car drove fine quite long. i ordeded all new coils anyway and see if this might solve it.
Model Year: 2005
replaced all coils today with two sparks as I replaced them 20K ago. same problem it even got worst
these wore the codes I read first time after replacing coils
