View Poll Results: Have you ever flushed your transmission fluid?
YES
36.00%
NO
64.00%
Voters: 25. You may not vote on this poll
Have a E60 with high mileage and no 'lifetime' transmission f
Old May 10, 2012 | 06:42 PM
brianstash's Avatar
My Ride: E60
Engine: N54
Do you have a 5 series with no transmission fluid flush done?
I have a 2004 530 with 107k miles on it.
Should I do the flush of the lifetime ATF and change the filter pan or leave it go?
How many miles you got?
Old May 10, 2012 | 07:04 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
i wouldnt "flush" the fluid, but i would drain the fluid and refill.
Old May 10, 2012 | 07:23 PM
brianstash's Avatar
My Ride: E60
Engine: N54
That's a great idea that no one has suggested.
Old May 10, 2012 | 08:10 PM
healthservices's Avatar
Old May 10, 2012 | 11:05 PM
Theo's Avatar
My Ride: 2004 E61 530D - Dynamic Drive - Active Front Steering Sport Seats - Voice Control - Head Up Display - Nav Pro - Bluetooth - Panoramic roof - Front/rear heated seats
Have/get it done, you'll notice the difference. The transmission won't be lifetime if you assume the fluid being so.
Good luck
Old May 11, 2012 | 02:29 AM
mporange's Avatar
Just had mine 2004 530i 115K serviced.
Automatic gearbox oil changed and new oil pan (the filter is in the oil pan).
Made some difference, but the old oil looked surprisingly clean.
Just remember to use BMW spec oil, see no reason to do a flush, just change the oil.
While you are at it you should change the mechatronic sleeve/gasket if you have an automatic.(do a search)
I did´t and regret that.
Old May 11, 2012 | 06:55 AM
Mobmatrix's Avatar
If you go to BMW in germany they will change the gearbox oil every 120.000 KM as normal maintenance
Old May 11, 2012 | 07:02 AM
bavariancowboy's Avatar
I just had mine done around 6 months ago and I currently have 66k on an '07. I am following Mike Miller's old school maintenance where possible (the fuel filter is inside the fuel tank and costs $500+ to replace so I will let that go). I had no issues at all but figure might as well keep the metal bits lubricated.
Old May 11, 2012 | 07:27 AM
M57D30-T2's Avatar
My Ride: 2004 530d SE,manual,beige Dakota leather,light wood trim,jet black.(alot will be changed)
when are you supposed to change the manual gear box oil on a 530d? ive never done it and mines now has 192 thousand miles.
Old May 11, 2012 | 02:56 PM
nagos420's Avatar
My Ride: 08 535i sport
Just did mine 08 535 57,xxxx. Probably do it again around 100,000 miles
