Hardcore vibration + check engine
On my way home from work today I accelerated to pass someone maybe accelerating for 2 seconds or so, suddenly my car started shaking violently and would barely accelerate. At first I thought I had four flats from how bad it shook. Sat back,in car and turned it on and noticed check engine light was on. On the way home it shook again twice at red lights, so I had to turn car loff and on. Takinig it in for service in 3 days, anyone know what it could be?
what does that even mean-your "cylinder heads are goin bad!" haha That is the most ridiculous comment ever.
Its not your cylinder head. It likely is a component of your valvetrain. I had a hyralic lifter and spring break and caused a violen shaking that was so violent I turned my car on and it literally was possessed and hardly would move. YOur under warranty so dont worry about it
My money's on the HPFP. Period.
Good luck with having the car fixed, Persian! Sure hope its not the "cylinder heads"
Whatever it is, the warranty should cover it, so sleep tight
I dont want to sound stupid what is the HPFP exactly, i have a 2007 530i, whenever im on idle, like on a red light or stop sign, the car start vibrating, you can feel it from the steering wheel and through your seat.
i took it to the dealer and they told me its the bearing of the exhaust that is worn off, we fixed it and still vibrating.
any help would be really appreciated.
thanks
thanks
My Ride: BMW 525i e60 (private) M-style,, Carbon Black, HUD, MM Interface.
And a BMW 325 e90 (Business),
An injector (Or multiple) or the unit(s) driving your spark plug(s). I had this several times.
HPFP = High Pressure Fuel Pump Could be it as well.. but I bet on my first assessment.
If it would be the valve train. It would be permanent (which, as you described, it is not).
