Hard Brake Pedal
Old 12-04-2014 | 01:24 PM
yelcab2's Avatar
My Ride: 2006 530xi touring
Engine: 3 liter
Default Hard Brake Pedal
I got a hard brake pedal on my 2006 Station wagon today. It is a little strange that ...
1. The brake pedal is OK for the first half of the travel, and then I have to push the hell out of it for the last half of the travel.
2. I can test the vacuum assist by turning the car off, pump the pedal a few times until it goes hard (vacuum is gone), start the car, and feel the pedal pushes down a lot meaning it passes the vacuum test.
So, it acts like there is vacuum there but not enough.
What is wrong?
Old 12-05-2014 | 12:35 AM
wcr3d's Avatar
My Ride: 2006 530xi w/Sport, Premium, Cold weather. Silver Gray Metallic, Black Dakota leather interior.
Of course that is not normal, I would have the codes read to see if anything shows up there.
Old 12-05-2014 | 10:02 PM
yelcab2's Avatar
Engine: 3 liter
Well, vacuum assist is totally gone now so the booster is likely broken
Old 12-05-2014 | 10:08 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
have you pulled off the vaccum line going to the booster, while the engine is running, and check to see if there is vacuum?
Old 12-07-2014 | 05:12 PM
Cricketts's Avatar
My Ride: 2010 BMW 550i M Sport. GPS, Satallite, Active suspension, Silver over Black in color with beige. 68k on the clock. My 10th BMW in forty years.
Model Year: 2010
Engine: 550 Msport
What the heck! it only $1,100.00. Been there.
Old 12-08-2014 | 05:49 AM
yelcab2's Avatar
Engine: 3 liter
did not have time this week to mess with this. Will do some trouble shooting tonight
Old 12-08-2014 | 05:50 PM
yelcab2's Avatar
Engine: 3 liter
Yes, checked vacuum at the booster connection, there is strong vacuum at the line.
Old 12-08-2014 | 05:51 PM
yelcab2's Avatar
Engine: 3 liter
Booster is only $150 from rock auto.
Vacuum pump on the other hand is $350.
Old 12-08-2014 | 07:54 PM
turboawd's Avatar
but pay a dealer to do it = $$$$$
Old 12-09-2014 | 11:45 AM
JasonH's Avatar
Second-hand brake boosters are pretty common and cheap.
They don't fail very often and every E60/E61 that is broken has one. I think they're the same for all engine sizes too.
Fitting isn't that bad - the main headache is that you have to completely bleed the entire braking system because you need to disconnect the brake lines to the master cylinder.
Quick Reply: Hard Brake Pedal
