H&R Sport Springs and Bilstein Sports, hitting bumpstops
4 Attachment(s)
I just installed H&R Sport Springs with Bilstein Sport Struts, now I keep hitting the bumpstops. Or the car is too low or the springs are too soft or both. Since the H&R Spring drop is 1.4-1.8 inch I was wondering if someone can recommend a spring that lowers the car a little less.
My car is even lower then the 991 with 10mm lowered Pasm suspension. |
Your Bilstein Sports have internal bump stops, so there's no need to re-install the oem bump stops. I too have the Bilstein Sports but with Eibach Pro Kit springs; they're not as lowered as your ride (Eibachs lower ~0.9 to 1.3 inches I believe).
Originally Posted by e6t.lab.rat
(Post 1528542)
You are right, and I did not install any bumpstops, the bumpstops I am referring to are the internals of the Bilstein. Good to hear that you like the Eibach, it is an option I am looking into. Is that pic of your front end with the Eibach? Thanks |
Originally Posted by Augustomf
(Post 1528562)
... Is that pic of your front end with the Eibach?
Thanks |
(Post 1528568)
Yes it is. Something definitely looks wrong seeing how the boot is crumpled like it is. I don't recall seeing my boot doing that. Is that pic of the rear shock? Maybe they installed the front springs at the rear (if that's even possible) and vise versa?
