Grinding Noise N/S Rear Wheel.... HELP
My Ride: 2005 530d M Sport, Carbon Black, Black half leather
I just been out for a drive and all of a sudden have got this loud grinding noise coming from my rear passenger side wheel.. I have new discs and pads all round, only a few months old so it shouldnt be that... any suggestions? im not sure if its safe to drive either
My Ride: Bmw 530d 2004
You should check if it's the wheel bearing...
1) Lift the passenger side rear wheel up with a jack
2) Take a good grip of the wheel and try to shake it
--> if you feel any backlash, it could be the wheel bearing or suspension parts
--> if there is backlash when shaking to left/right, but no backlash when shaking up/down, it's probably the suspension parts
--> if there is backlash when shaking to left/right AND when shaking up/down, it's probably the wheel bearing
--> if there is backlash when shaking to left/right/up/down, ask someone to press the brake pedal while you shake the wheel, and if the backlash disappears, it's the wheel bearing
If you can't feel ANY backlash in the wheel, then it's probably a dragging brake.
- Antti -
- Antti -
I suspect it has something to do with the last person who worked on the car and what he did (or did not do).
I couldnt have asked for a better responce!!! Thank you, shall go out with a friend in a min and give it a good old check over
Thank you so much
Thank you so much
