Green Led light blinking When turn on the Headlights
Hello,
Its normal a green led light blinking when turn on the Headlights ? To be more exactly, the green led is be on the left side of the bottom that put turn on the headlights.
Thanks for your help guys and sorry about the question. I bought this car 3 weeks ago and I need learn more about he.
Regards,
André
Regards,
André
You have an issue with the headlamps... for me my active headlamp was frozen (the motor malfunctioned) and I needed to replace the entire headlamp assembly
Here is the page in the manual - manual - headlamp malfunction
Its anywhere from $1400-1600 US... not cheap!
So, my active it's not work ?
I'll need change the headlights ????
Sorry for the questions.. But I need know more about.
In BMW dealer they will replace a motor ???
THanks for your help.
For me the entire active headlamp needed replacing(driver side headlamp assembly only)... I think in some cases the stepper motor can be the issue but in most of what I have read and in what I experienced it was the entire active headlamp assembly.
Take a good look at the lights and you should be able to see that one or both have stopped moving and are off center. This could be very annoying for oncoming traffic it it is aimed at them....
Jaycal,
Very, very thank you for your help...
My car is a 530i 2004, maybe the motor its not work.
I'll need go to the Dealer see what happen.
Here in Brazil, everything that you do on Dealer is 8x more expense that in USA. This is so ridiculous !!!!!!
My Ride: BMW E60
Model Year: 2016
It could be the AHL unit and not the motor. But yes, the blinking green light indicates something is wrong with the adaptive system. If it indeed is a broken motor, depending on where it's stuck/pointing, maybe you can just live with it.
My Ride: 2004 530i
premium package/active steering/auto sunshade/tiag/black dakota leather/logic 7
35% tint all around
19' DPE GT7
This has happened to me twice now and both times during the winter. both times I had to replace the entire headlight assembly, luckily for me the dealer was nice and covered it both times under my CPO warranty.
