Greasing up steering shaft u-joints
My steering wheel makes a weird deep whining sound when you shut the car of and the steering wheel raises up for you to exit the car, my question is where or what joint should be greased to fix this?
My Ride: 545i
Not to sure. Take some of the trim off around the steering column and see where the pivot points are. Maybe start there.
My Ride: 2006 BMW 550i
i too was chasing a low speed and parked clicking noise while turning the wheel. i first checked the steering joints like mentioned. i ended up finding one of my control arms was the culprit. the bolt that holds the bushing of the control arm is not a tight fit, so the control arm bushing was shifting slightly back and forth on the bolt. a little while earlier a mechanic changed my shocks, and i guess he didnt tighten the control arm bushings enough. i just had to tighten it up the bolt and that was it.
When I look down the steering column it looks like the pivot is way back, Im wondering if the steering column follows some kind of verticle track up near the steering wheel that could cause the sound as it sounds like its right behind the steering wheel??
My Ride: FX35 Supercharged
i have this same steering wheel click. now the odd thing is that if i put the car into reverse and turn the wheel it does not happen. If i am going fast, it does not happen. it only clicks when i am turning to the right. if i hit a bump and i am turning to the right, it does'nt happen.
My Ride: 2006 525i
Model Year: 206
Vman33
03-14-2022 04:43 AM
Johnnywadd
09-03-2015 01:23 PM
