Greasing up steering shaft u-joints
My Ride: 545i
I have a clicking in my steering. After searching found out that the u-joints on the steering shaft dry out and just need to be re-greased. I was able to grease the top u-joint by taking the kick panel off but it seams the bottom one is on the other side of the fire wall. Just wondering if the bottom u-joint is accessible from underneath the car? I have the sport package and don't want to take all the under-body paneling off if I don't have to.
Also, recently changed the tie rods. Steering is very tight, just clicks when low speed maneuvering.
![](http://static.bmwfans.info/images/epc/MTMzMDM5X3A=.png)
My Ride: 545i
So after no replies I decided to just tackle it. Ended up having to take the under body paneling off and then had to remove the belly pan and loosen the left lower splash shield to access the lower u-joint. I was able to grease it up, but the clunk is still there. Not as bad, but still there. Might end up having to replace the steering shaft. So if you have the clunk and your sure its not your tie rods, grease up the joints before they get beyond repair. :thumbsdown:
My Ride: 545i
White lithium grease. Just work it into each u-joint by hand. Mainly the bottom one because there is no dust boot or anything covering it. Its exposed to the elements.
My Ride: 08 528i
I had a clunk on the steering wheel and was repaired by changing the steering lower joint assembly
lowerjoint
lowerjoint
My Ride: 545i
lowerjoint
lowerjoint
My Ride: 545i
I would show you with TIS online but it appears its no longer available. If I remember correctly there is a carpeted panel to your left that butts up with the center console. There is 1 or 2 screws near the firewall end of it that have to be removed then you slide the piece towards the front of the car to remove it. Then just remove all the screws holding the kick panel and disconnect the wires for the kick panel speaker. I I believe the screws are phillips.
