Glow plug/controller error
Old Aug 3, 2015 | 05:49 AM
lennox1's Avatar
My Ride: e60 525d msport lci
Default Glow plug/controller error
Hi
I hade an error message in dis and Inpa showing glow plug no 2 fault 4222. I have replaced all 6 plugs and when tested glow plug with multi meter it was sowing as faulty the oham reading was all over the place.
I have scanned it again and still showing glow plug no 2 same fault, could this be the glow plug controller or would it show all glow plugs down if that was at fault. any help would be appreciated.
Thanks
John
Old Aug 3, 2015 | 04:32 PM
ripley's Avatar
My Ride: 2007 E60 530d
Engine: M57
I have the same issue - replaced all six plugs and almost right away one was reported as bad.
The controllers are known for being a source of issues so I have another one ready to install when I get a few hours - its tight down there. I didn't have it when I changed the plugs.
Not really a running issue yet since it will regen fine with 5/6 working.
Old Aug 3, 2015 | 05:39 PM
lennox1's Avatar
Thought it would not regen with a glow plug down as my dpf light keeps coming on so need to get controller ASAP. Just wasn't sure if a failed controller would only show one plug down, I really should have scanned it when manifold was off when I replaced plugs
Old Aug 3, 2015 | 06:58 PM
ripley's Avatar
Engine: M57
I don't think a single bad glow plug is enough to stop regeneration.
Old Aug 5, 2015 | 03:05 AM
JasonH's Avatar
A single glow plug failure will not stop regeneration. My car is one glow plug down and it's definitely regenerating.
Old Aug 5, 2015 | 02:47 PM
lennox1's Avatar
Thanks for the comments guys.
Just replaced the controller today and all faults cleared, so just need it to regen, or force one manually.
Old Oct 9, 2015 | 05:13 AM
Tigr's Avatar
My Ride: BMW E60 530d 2004
Model Year: 2004 Apr
Engine: M57N
Originally Posted by lennox1
Hi
Thanks
John
Dear John, could you please explain a little more at what point did you checked with the Multi-meter? What are the expected values for the working glows?
I have a similar problem (error code is: 4203), so I want to understand how to check the glows before buying anything...
Tigran
BuddyB
Aug 17, 2017 12:48 AM
fabolous531
Oct 18, 2015 12:22 PM
umnitza
Sep 2, 2015 11:28 AM
Bounce
Aug 31, 2015 10:04 AM
mmarco50
Jul 25, 2015 11:17 AM
