Glove box Fuse 30 draining the battery - E60 2004 530i
Old Aug 27, 2024 | 10:40 PM
RichieRRR's Avatar
Probation Members
My Ride: 2004 E60 530i
Unhappy Glove box Fuse 30 draining the battery - E60 2004 530i
Hello,
I have a problem with my 2004 530i E60, I am hoping someone can assist me with.
Fuse 30 in the glove box (Air conditioning-Automatic) is draining the battery within ~an hour.
This doesn't seem to be a "module not going to sleep" - this seems more like a short circuit on that circuit.
If I remove fuse 30 in the glove box (Air conditioning-Automatic) the car / battery will last for months.
If I re-install fuse 30 in the glove box (Air conditioning-Automatic), the battery will be completely drained flat within an hour or less.
I've done a LOT of looking around online for this issue and I can see a lot of different suggestions
"Master ballast resistor"
"Final stage unit"
etc ..
I don't want to just blindly start replacing parts hoping for the best.
Is anyone able to tell me what is on this circuit so that I can pin point this issue?
Thank you in advance for anyone who took the time to read this far. 🙏
Old Aug 28, 2024 | 12:24 AM
donpb's Avatar
My Ride: '06 530i N52
You need to isolate the culprit on that circuit. A wiring diagram or an electrical specialist would help.
Old Aug 28, 2024 | 06:36 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
You know the circuit so just like @donpb stated need to isolation the parts on that circuit. Start unplugging and see which part is draining the battery.
Old Aug 28, 2024 | 06:39 AM
Heck looking at the diagram the IHKA is the only thing on that circuit so replace it. If you think it's a short then you'll have to look at the wires. Honestly I would hook it up to INPA and run some tests to double check it but that's telling me you need an IHKA from what you're explaining
rev run d
Oct 16, 2016 03:35 PM
GreenMTNE60
May 14, 2016 05:20 AM
biggurs
Feb 2, 2012 02:24 PM
bdn
DIY: Do It Yourself
Jun 5, 2010 07:32 AM
Merzbow
DIY: Do It Yourself
16
Jul 12, 2005 08:35 PM
