Giving exact torque to the bolts (how important?)
My Ride: 2006 525i / Premium / Winter / Comfort / Navigation / Ipod / Satellite Radio / HUD
I'm a beginner DIYer that decided to do maintenance stuff myself. Could not find a discussion on the following topic so I'm posting this. If you know of a previous discussion, please paste a link. Thanks to all in advance for replies.
1) How critical is it to give an exact specified torque to the caliper bolts (the 2 bolts that need to be taken out to replace the front brake pads) as well as the wheel bolts?
2) what tools do you need to give caliper bolts exact torque? Is there a tool that work for both caliper bolts and wheel bolts?
Yes you need a torque wrench. Most likely the ones for the wheel bolts won't work with caliper because of the range in torque available. I have the following two:
For the smaller bolts
http://www.sears.com/shc/s/p_10153_1...7&blockType=G7
For wheels, hubs, etc.
http://www.sears.com/shc/s/p_10153_1...3&blockType=G3
It's always recommended you set the proper torque if possible.
Model Year: 2010
I use a torque wrench like this one:
Craftsman Microtork Torque Wrench, 20-150 ft. lbs., 1/2 in. Drive
Add a set of 1/2 inch sockets and one can work on wheel bolts, caliper bolts and other large bolts.
only problem i've found is in tight spots, i can't use such a big torque wrench it just won't fit.
Model Year: 2010
What about adding a socket wrench extension?
Also, due to the large forces involved, I would shy away from anything less than a 1/2 inch drive.
My Ride: '06 550i
'84 Nissan S12 Turbo
I got my 1/2" drive torque wrench from Summit Racing. http://www.summitracing.com/parts/SUM-900042/
Works like a champ, even though it's just a cheapo. I've been using it now for about 2 years. Had one just like it before for about 8 years.
I just did my brakes the other day, and used the torque wrench on the wheel bolts, calpiers, and caliper brackets (took everything off to paint).
The caliper pin bolts are allen bolt style. I don't remember the size, but you can get a set of allen sockets at Lowes, Home Depot, auto parts store, etc. As far as torque, from memory the guide pin bolts are 25 ft lb, and the caliper bracket bolts are 70 ft lbs. There is room to torque everything down with that size wrench.
i've been working on cars for years, including brake pads. it is not important to get every bolt to a torque specification. in fact the only time i ever use a torque wrench is on the wheels, and that's mostly because the intense amount of rotation that they go through, they will usually loosen over the first 20 miles or so that you drive your car after you put a wheel on. everything else get it about as tight as you can with a 6" socket wrench, unless you are working on soft aluminum. also, the bigger the bolt, the tighter it needs to be usually.
i always recommend using blue loctite with brake calipers, always. that's far more important than torquing your bolts down to spec.
http://www.tooltopia.com/sk-hand-tool-74531.aspx
