Gearbox specialist recommended not servicing my gearbox?
Old Feb 14, 2022 | 11:08 PM
Llama's Avatar
My Ride: E60 550i
Default Gearbox specialist recommended not servicing my gearbox?
Helo, today I requested a gearbox service from a reputable and recommended gearbox repair business .
I was shocked when he said he wouldn’t recommend me serving it(money for them..).
the reasoning was that the car (2007 175000km) (Auto) Doesn’t have any major issues, just some clunky changes when cold mostly. He said because it’s unknown if the car has had a gearbox service done before, the old oil might not drain properly and the new oil will just pick up the old sediment and become “sticky” possibly causing bigger problems.
Im not sure if i understood correctly or explained it precisely here, but what are your thoughts on this?? Thanks
Old Feb 16, 2022 | 11:03 AM
BartvZessen's Avatar
My Ride: E60 Lci 530i
Engine: N53
if he does it properly, he should remove the old oil and flush the whole system with new oil until only new oil comes out.
that should not result in any problems. However, i heard the CAR NINJA say that someone (instructor) from ZF said not to replace the old oil with new, but to put the old oil back in
Old Feb 16, 2022 | 12:43 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Do not flush the transmission. Do a drain and fill every 50k and you'll be fine. ZF recommends fluid change
Old Feb 16, 2022 | 08:22 PM
donpb's Avatar
My Ride: '06 530i N52
Sounds like an honest guy to me, but if you really wanted it done, you could have told him just do it but the resultant would be on you and not him.
LandRange
Oct 30, 2012 05:06 AM
bigun
Apr 19, 2011 01:53 PM
gary belfast taxi driver
DIY: Do It Yourself
May 21, 2008 02:05 PM
chrisburns
Mar 16, 2008 05:59 AM
Robert A
Oct 17, 2007 01:07 AM
