Hi guys had a transmision problem pop up today code came up on carly 004f82 gear ratio monitoring clutch b/ loading trailer 1/r it's a 2008 bmw 535d it had a stage 3 xhp map on but I've flashed back to stock .
any body know what this is and what gearbox would be in thos or how I can find out to order the service parts
.also these are my read outs of xhp
Buddy - I had something similar - after a lot of pain changing gearbox fluid etc I had to take it to a ZF accredited specialist and they did a rebuild for £2k. worth every penny but quite a sting. Highly recommend going to a ZF specialist for auto boxes of this age - they're all worn out and BMW tell you they're sealed for life but ZF tell you they should have a service every 40k miles..
[QUOTE=jonhamil;1609973]Buddy - I had something similar - after a lot of pain changing gearbox fluid etc I had to take it to a ZF accredited specialist and they did a rebuild for £2k. worth every penny but quite a sting. Highly recommend going to a ZF specialist for auto boxes of this age - they're all worn out and BMW tell you they're sealed for life but ZF tell you they should have a service every 40k miles..
Hope that helps?
Jonathan[/QU
thanks I've just done the sleeves and seals and the filter and oil today now it seemed ok at first then on a longish run I stuck my foot down and it jumped out of gear and revved like mad transmision fault came up now clutch e monitiring has come up
