gear moving up at low speed instead of going down
this is a recent problem i am having at low-ish speeds ..
this happend to me about 4 - 5 times in the last 3 weeks and everytime it happend i was at a turn
when going into a turn i let go of the gas pedal and let it roll until im out of the apex, as i hit the gas i get a big jerk where i can feel the gear move up and then down and this only happens when i drive at regular speeds .. i dont get this problem if im driving agressivly .. i even took the car into the delearship and took an engineer on a drive with me but after many failed attempts i gave up and tried expaling the problem . he told me they would look into it .. a day later i got a call saying that they rectified the problem .. but as i left the delear i had the same experince
i even tried the 25 second trick to reset the gear box .. but i feel its made it worse .. i dont know what to do and my warrenty is getting over in weeks time ... has anyone had this problem ??? if so what fixed it
My Ride: Black E60 530i
Originally Posted by prase007' post='508730' date='Dec 20 2007, 05:38 AM
Hello, I also got 06 530i and never noticed this problem but i think what you say the car is doing is correct. As you are rolling without the gas, the car is trying to save your fuel by engine braking, as you softly step on a gas pedal after, the car is thinking you want to go so it shifts up to higher gear since its better for fuel economy, after you notice it, you step on a gas pedal a little bit harder so it shifts to the lower gear again. If its really issue, you dont have to be scared about your warranty since you have reported it before your period ended.
i know the car records driving style so is ther anyway to clear this apart from the 25s trick .. i dont really think that works
Originally Posted by PSB' post='508752' date='Dec 20 2007, 08:08 AM
i understand what you are saying but i havent changed my driving style or anything .. so why is this happenings now ?
This sounds like the dreaded transmissions slam problem. you need to have your dealer update the transmission software.
My Ride: 2007 530i | Silver Gray/Blk | Step-Tronic | Sport/Premium Package | Logic 7 | PDC | Fold-Down Rear Seats
Originally Posted by PSB' post='508728' date='Dec 20 2007, 02:16 AM
anyone ??
If you reported the problem before the warranty runs out and they failed to fix it, it will still be covered. Just make sure you tell them asap that the problem is still there and that they didn't fix it. Try and get a copy of something in writing to prove you first took it in for that fault before the warranty expired.
i really like this car and it handels amazing but the truth is this car has tooo many small porblems .. its the little things like squeks & rattles which bring this car down .. only if the build quality was a littlwe higher it would have been perfect
socale39
09-05-2023 08:30 AM
