Gas Mileage
Old Sep 9, 2005 | 06:52 AM
grungyspeed's Avatar
I recently took a five hour trip on open highways with my 545. I averaged about 27 miles to the gallon on the highway at 85mph per my OBC. Any of you guy experience similar mileage?
Old Sep 9, 2005 | 07:13 AM
Ricracing's Avatar
Originally Posted by grungyspeed' date='Sep 9 2005, 04:52 PM
I recently took a five hour trip on open highways with my 545.? I averaged about 27 miles to the gallon on the highway at 85mph per my OBC.? Any of you guy experience similar mileage?
[snapback]168717[/snapback]
Welcome to this great forum .
You might first want to explore all the features and data you'll find around here.
Use also the Search mode
You'll find the answer to your question here:
http://forums.e60.net/index.php?showtopic=...5&hl=gas+milage
This IS a great site!
Old Sep 9, 2005 | 07:18 AM
hpowders's Avatar
I also get 27 mpg on the open highway. Too bad we have to get off!
For 1200 miles about 70% highway, 30% city, I average 20 mpg.
I think that's pretty good for a V8.
Old Sep 9, 2005 | 04:09 PM
cobradav's Avatar
The faster I go the better the MPG
Old Sep 9, 2005 | 05:29 PM
znod's Avatar
Similar results for me.
Old Sep 10, 2005 | 04:58 PM
TB CD's Avatar
Yes, highway trips at 80 I'd get about 28-29 mpg in my 530 and about 27-28 in the 645.
IMHO, the 645 could use some taller legs in 6th gear. I understand the 545 has taller gearing in 6th. You are a little bit too far "into the candy" in 6th gear when high speed cruising in the 645ci.
When doing 80+, the engine is revving a little too high than it needs to IMHO. Good for performance, but bad for economy. The 4.4l V8 has enough grunt around 2000 rpm that it should be geared for 2000rpm at 80mph, not 2400 or so.
My Vette gets 33 mpg highway at 80mph. 80 mph is right at 2000 rpm with the manual trans. Actually it gets30+ all the way up to past 100 mph.
Old Sep 10, 2005 | 06:13 PM
cobradav's Avatar
IMHO, the 645 could use some taller legs in 6th gear.? I understand the 545 has taller gearing in 6th.? You are a little bit too far "into the candy" in 6th gear when high speed cruising in the 645ci.
When doing 80+, the engine is revving a little too high than it needs to IMHO.? Good for performance, but bad for economy.? The 4.4l V8 has enough grunt around 2000 rpm that it should be geared for 2000rpm at 80mph, not 2400 or so.
My Vette gets 33 mpg highway at 80mph.? 80 mph is right at 2000 rpm with the manual trans.? Actually it? gets30+ all the way up to past 100 mph.
[snapback]169289[/snapback]
Not a whole lot of difference - but some - between 545 and 645 with like transmissions. More difference between trannies.
See here (corrected in edit):
Old Sep 12, 2005 | 12:42 PM
Thanks everyone. I have been around for a while watching, but this was my first post. The 545 is my first sedan after a string of 911's over the last 10 years.
Enjoying it so far.
Old Sep 13, 2005 | 09:27 AM
juan2mini's Avatar
grungyspeed:
Welcome to the forum. I just returned from a 700 mile round trip, almost all freeway. OBC put mileage at 29.5. When I filled my tank and did the math, I got 22.5 miles per gallon. The OBC had my average speed at 78.3 - I am pretty sure that was right.
andymax
May 20, 2018 11:32 AM
PakiBeamer
Dec 9, 2016 04:40 AM
bestofthebest
Mar 28, 2016 02:47 PM
Jiawei Zhao
Oct 21, 2015 08:46 PM
bimmerspeed
Sep 3, 2015 09:29 PM
