Gas/ Fuel smell in the rear driver's side wheel well - 2009 528i, 190k miles N52
Lately I have been smelling gas/fuel from the driver's side rear wheel well. The smell is more prominent after driving the vehicle, even short distances. I've searched around online forums but have not really found any good means to try and trace the smell, as mostly results come up for E90's.
I plan to replace the brakes/rotors all the way around in two weeks when the brake wear sensor and a few other components arrive. With the wheel off I plan to remove the protective wheel lining to inspect to see if any fuel lines may be corroded or if I can maybe see the fuel/evap canister. There has not been a decrease in performance, fuel consumption, loss of MPG nor have I noticed the fuel level go down any more than normal. I keep my 528i well maintained with the usual common fail areas/components already addressed and replaced. I just noticed the fuel smell for about week now whether parked in the garage or out in the apartment parking lot. If anyone has any advice, tips, suggestions or material I can review to try and trace this mysterious fuel smell that would be great. I just a fuel pump/fuel filter replacement on my 04 Miata that was not fun! Unfortunately the Miata is not best for daily driving as it has an issue randomly not starting (immobilizer/ecu problem I suspect). Hoping this is a relatively easy fix or if it's something simple as an evap canister being wet - would I need to worry about it? Or just live with the small gas smell? V/R, MD |
Check under the rear seat first.
Originally Posted by donpb
(Post 1611860)
Originally Posted by thedoodwitamullet
(Post 1611876)
the 5 series are notorious for the driver side fuel pump taking a shit. Normally it starts with the hat. I believe it's the hpfp. You'll see when you lift up the rear seat there is the hpfp and lpfp on passeneger side
I had this same problem and fixed it by replacing the fuel filter and pickup that's under the DRIVER side rear seat.
There's lots of articles, but one thing you really want to do is DISCONNECT THE BATTERY. You know that humming that your car does at random times when its just sitting there? That's the fuel pump getting ready for a drive. You don't want that spraying your interior when you've got it apart. |
Thank you everyone. I replaced the fuel sending unit/filter assembly and the leak was fixed. Looks like it had a hairline crack in it in the nipple that connects to the hose. Unfortunately I didn't buy the special metal ring removal tool and although I thought I chiseled it all the way tight, when I filled up past 3/4 of the tank fuel leaked a lot at the gas station. had the car towed and sat in my gravel driveway with oil absorb to catch some of the spilled fuel. I have since bought the tool and should arrive today. Overall it wasn't too terrible, I just highly recommend buying the $15 tool than the hammer/chisel/screwdriver method.
Thanks for the update.
Thanks for the update. Glad you figured it out. I've never used the tool but then again I've always used a pry bar to do spend the locks on and off.
(Post 1611985)
I replaced the brakes (pads/rotors) all around and it's due for an oil change that i'll tackle next weekend. Otherwise I hope to keep this car running to at least 200k. It just hit 190k a week ago. |
So the new metal ring removal tool worked like a charm. Removed and reinstalled it correctly and now no leaks. Thanks to everyone for the help and assistance throughout this entire ordeal.
Hope this might help others in similar situations. |
