535d
My Ride: 320d SE (E90) manual - Sapphire Black, Beige Leather Sports Seats, Burled Walnut, Heated Seats, Sunroof, Comfort Access, Hi-Fi sound, Bluetooth, Side-Window blinds, Through-Load, Luggage Net, PDC Front & Rear, Adaptive Xenons, Style 158 17", Chrome Grill & Window Trim, Blackline Tailights, Power folding/dimming side mirrors, Split Armrest, Dual Zone Climate, Cruise, LEDs on door handles, iPod nano, SE K750i
Originally Posted by fraseman999' post='381796' date='Jan 22 2007, 10:52 PM
Why is there not an option for a manual in the 535d?
This is what i thought. Getting my 530d done this week, when its finished it will have about the same performance as 535d. Its a manual! Just wondering what the long term effect will be on the box.
if you allow enough time for the engine and transmission to warm up after you start the car, then the difference in reliability will not be great... if you just mash the throttle, then its gonna go BOOOM
Originally Posted by Raighne' post='381810' date='Jan 22 2007, 11:13 PM
Rumour is that the engine has so much torque and they would have trouble finding a manual transmission that could handle that (with long term reliability that is).
ABC
My Ride: 535d M-Sport '06 Plate - Carbon Black - Black Leather - Pro Sat Nav - Logic 7 - HUD - Bluetooth - Privacy Glass - 172M 19" Alloys - Heated Seats - PDC - Adaptive Headlights - Extended Voice Control - Paintshield Extended - M5 Boot Finisher - Bright White LED Internal Lighting - Dension Gateway 500 Ipod/USB/Aux Integration
Yep!
In standard form (not LCI model):
535d = Nm/rpm 560/2000
M5 = Nm/rpm 520/6100
Originally Posted by aybeesea' post='382052' date='Jan 23 2007, 08:39 AM
Does the M5 have less torque than the 535d?
ABC
ABC
Although you could have a manual in conjunction with a 535d , a couple of wrong downshifts and your gearbox is toast
(and also on the new manual e60 m5... check some of the posts on m5board.com ... a couple of toasted trannies already)
My Ride: (E60) 535D M-Sport (DMS)
Originally Posted by MarcsOnFire' post='382059' date='Jan 23 2007, 04:19 AM
Yep!
Torque is possibly more useful that power in real world driving as you can mash the throttle in higher gears & still take-off (also due to the 535d being an Auto), however to make supersonic progress at certain speeds, an M5 driver would probably have to drop a cog or 2 (DMS on an M5 helps mid-range no end though). Saying that, dropping a cog & listening to that V10 blip about 1K rpm is so nice it's often better to play.
The 535d is a fabulous car though & it pushes the boundry of diesel cars to the max.
My Ride: 520d m sport
Does anybody no would the normal box from a 520d m sport bolt straight onto the 535d engine and work wit out any hassle......I no this box isint reliable enuf on dat engine but if it work it would do me (I have m/t 520d wit engine blown....and was going to buy a wrecked 535d wit good running gear ?)
My Ride: Bmw 520d m sport
In the same boat
Did you do the swap mate? I'm looking to do the same.
