Fuel Injection Flush
#21
When they put your engine together at the factory they usually put in brand new injectors that have not been flow tested and there tolerances can be off but acceptable by manufacture standards. What these companies do is flow test your injectors and then balance them by trading up injectors that are within tighter specifications from each other and that is what will make your car run smooth and almost electric. Sometimes guys that upgrade turbos and such send brand new injectors to them to get balanced and flow tested before they tune their cars.
Here is one of the popular companies that perform the service. The one I used was cheaper but I cant find it right now.
http://www.rceng.com/Fuel-Injector-C...YN5KfsMYABFgdM
#22
If some of you can hold out until April I will do a write up on how to flush your brake fluid with speed bleeders.
The good thing with speed bleeders is that it is very easy to do with out any mess or loss of fluid. I have had both a vacuum bleeder and a pressure bleeder in the past and they just don't do the job as quickly or affectively as the speed bleeders.
I can only imagine BMW like most things charge a good amount for something that is very easy to do.
Vman33
03-14-2022 04:43 AM
bestofthebest
03-28-2016 02:47 PM
