Fuel fitter?
So my car will hit 60K in by Friday, I'm thinking of replacing the plugs, and the fuel fitter? I read somewhere these car doesn't have an external (gas) fuel fitter like the e39s... is this correct?
also, beside the plugs, and intake fitter, cabinet fitter, anything else I can do that's DIY?
Check out the DIY forum...Rizbel made a nice DIY for it. I also suggest after draining the coolant from the valve, squeeze the hoses to get as much out as possible. When I changed the water pump, I found lots more coolant trapped inside the hoses connecting to the pump and more if you remove the pump but you wouldn't want to remove it yet.
Vman33
03-14-2022 04:43 AM
