FTM to TPMS upgrade
FTM to TPMS upgrade
Is it possible to upgrade my 2004 to Tire Pressure Monitoring System? I'm annoyed trying to find the leaky tire, considering that for some reason I've had several tire issues in the last 3 months.
My Ride: 2008 550i M-sport, retrofitted heated M-sport steering wheel with paddles, Sport-auto transmission
You're better off just getting into a habit of monitoring the tires manually on a regular basis to determine the culprit tire (and recognize that the FTM system will occasionally give false alarms, ie. with ambient temp changes), then take it to a reputable shop for repair/replacement.
My Ride: 2004 530i
premium package/active steering/auto sunshade/tiag/black dakota leather/logic 7
35% tint all around
19' DPE GT7
Whats wrong with FTM, I personally prefer FTM. My Murano has TPMS and I with it didn't, in the winter on really cold days it always goes off saying I have low tires when I don't.
FormerE30Owner (05-02-2022)
Administrator
Can someone explain how TPMS operates and what you need on the wheels/tires themselves to monitor it? In other words, if I have TPMS currently, and want to change my rims/tires, what do I have to do to ensure I still have it? I've noticed that when some sell their wheels/tires, they say that TPMS is not included. I'm just trying to understand what they mean by that. Thanks!
With all the problems people have with TPMS why would you want something like this installed?
If a person really wanted to install something like this I guess you could put an aftermarket system on.
Fix the issue you have, which is the leaky rim or tire. All the tpms will do is tell you that tire is low, it is not going to fix the leak, it is not going to put air in the tire, you will still have to find out the cause of the leak and fix that, so you are still in the same boat your were before.
Our big fat soft tires are nail magnets ... I feel your pain! Anytime a remodeling job is going on in my neighborhood I can count on picking up a nail or screw!
But FTM or TPMS should alert you nearly equally. Aside from regular tire pressure checks I suggest you invest in a portable 12V air compressor to provide a little extra help should you need to correct tire pressure away from home. I suppose a good road service plan wouldn't hurt either.
Good suggestion on the 12v pump, as I have one. Sometimes the leak is so small that I cannot visually find it. I can usually feel the wobble and when I do find the offending tire, it is off by only 3lbs as measured by my Accu-Gauge.
My Ride: e60
dont bother retrofitting
:l
just buy an aftermarket add on
http://www.vulcantire.com/orange_409_sys.htm
:l
My Ride: 2008 550
DPE S7
CF Front Splitters
TPMS is a little module-looking part that screws inside the wheel valve opening and it communicates with the sensor on the car to determine the tire pressure. If you sell your wheels and or upgrade wheels make sure you take the TPMS sensors out first (taking the tire off), or that the new set have them included.
