FTM system
Old Jan 17, 2005 | 08:10 PM
ponster's Avatar
I have a 2004 525i with the Flat Tire Monitor system. I would like to know if I change my stock wheels for aftermarket ones, is there any sensors that I need to transfer to the new wheels so my FTM system would continue to function properly.
Thanks,
Ponster
Old Jan 17, 2005 | 08:16 PM
zippers525's Avatar
No, it should work fine. You just need to reinitalize the system.
Old Jan 17, 2005 | 08:23 PM
dindae520i's Avatar
My Ride: June 2004, 520i, Sapphire Black, Black interior. January 2003, VW Beetle 1.8T, Black Interior & Exterior.
Just a quick question....How long does initialization usually take anyway? Mine takes forever and I usually exit not knowing whether it's done or not. I have waited up to 5 minutes without any info appearing to say if it's done or not.
Old Jan 17, 2005 | 08:30 PM
Hormazd's Avatar
[snapback]80274[/snapback]
Yes I made the mistake of initializing when the car is stationery (as per instructions). You have to then drive to complete the process.
Old Jan 17, 2005 | 10:56 PM
alohalc's Avatar
welcome aboard, ponster !
Old Jan 18, 2005 | 07:25 AM
kscarrol's Avatar
My Ride: E90 M3
Model Year: 2011
I've only had to re-initialize once and it took closer to 10 minutes of driving around before the iDrive switched from "initializing" to "working" or whatever it says. Anyway, it does take some time. I almost gave up and parked the car.
Old Jan 18, 2005 | 07:29 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Exactly. It does take time to reinitialize the system. All you need is patience and it will complete...
Old Jan 18, 2005 | 03:02 PM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
Welcome aboard, ponster !
Old Jan 18, 2005 | 04:16 PM
JDN's Avatar
JDN
I think the 10 minutes is referencing rolling time. The wheels have to be rolling for FTM to do its job. It may take a 15-20 minute drive in Dallas to get 10 minutes of rolling time. Also, I air the tires and let the car sit in the garage until I am going somewhere that will easily log in the 10 minutes of rolling time. As long as one tire isn't actively leaking, a few hours or a day in the garage after setting the correct pressures should not matter.
Old Jan 18, 2005 | 07:22 PM
SueBMW's Avatar
Yes, and this is all, strangely enough, in the manual.
I thought it was taking forever too, since the instructions are confusing as they appear on idrive. So I read the manual. You start to initialize, then start driving.
