FTM errors since replacing CCC
Old 03-18-2024, 10:57 AM
  #21
darkunderlord's Avatar
My Ride: 2004 545i
if the MOSTGW is in the CCC, then that still makes me think it's about the CCC etc. ugh..
Old 03-18-2024, 12:01 PM
  #22
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Or it can just be a bad CCC. Are you working on it now. I can remote in using Anydesk and see what's going on
Old 03-18-2024, 12:03 PM
  #23
My Ride: 2004 545i
No I still have an hour or so until I am done with work. I work from home. I could probably start the car and remote into it and then let you remote into me, but I would expect you'd want me in the car.
Old 03-18-2024, 12:09 PM
  #24
My Ride: 2004 545i
as far as the two MOSTGW errors, I did code an AUX cable config into it, but am still waiting on the cable to arrive. I think it's possible that at least one of them is from that?
Old 03-18-2024, 12:19 PM
  #25
Model Year: 05 530i
Engine: 3.0 M54
No it doesn't read errors from a missing aux cable.
Old 03-18-2024, 02:06 PM
  #26
My Ride: 2004 545i
so does INPA have recent codes, stored codes, or both? Just wondering how many should "go away" when I clear them.
Old 03-18-2024, 02:28 PM
  #27
Model Year: 05 530i
Engine: 3.0 M54
They have every code that has popped up since the last clearing. You see if it's a present code or not present if you actually read the code from the module
Old 03-19-2024, 01:47 PM
  #28
My Ride: 2004 545i
let me know if you have time today to remote in. I used a simple Torque app on my phone to clear the regular codes. Not sure how to do it with the BMW softwares I have.
Old 03-19-2024, 02:51 PM
  #29
Model Year: 05 530i
Engine: 3.0 M54
Install anydesk and PM me the address
Old 03-19-2024, 05:01 PM
  #30
My Ride: 2004 545i
Just took it out for a spin and still acting the same. I'm not sure what is different about using trace files and man files, but I pretty much tried the same thing in Man files too I think. It's so bizarre that it thinks it has FTM. My mechanic who owned the car before me said he's never heard of an iDrive without FTM, but honestly I just want the damn thing to have the errors go away. The dash is like a xmas tree. Any other ideas?
Also, I need to research how to reset the sensor on the steering column so I can get my turn signals back to normal too. I am getting the active steering rack replaced soon too.
Quick Reply: FTM errors since replacing CCC
