Frustrated with new wheels
Old 05-23-2009, 12:20 PM
  #21
PraiseTheLowered's Avatar
Originally Posted by forced528' post='887663' date='May 23 2009, 11:42 AM
I bought it from http://www.323motorsports.com/shop/index.php out of Inglewood. They're the only ones that had them available. I am glad I haven't sold my original wheels since I may end up keepin' em.
what brand?
im not searching through all those wheels
you need to call the manufacturer and ask what the hub size is for their wheels
Old 05-23-2009, 01:03 PM
  #22
forced528's Avatar
My Ride: 2008 528i 6MT, Sport Pkg, Prem Pkg, sprint booster, ram air, BMC filter.
Originally Posted by PraiseTheLowered' post='887723' date='May 23 2009, 04:20 PM
what brand?
Miro M6 reps. I'm callin' them Monday.
Old 05-23-2009, 01:15 PM
  #23
Gene's Avatar
hopefully they are open on memorial day...
Old 05-23-2009, 05:40 PM
  #24
mhs525's Avatar
Originally Posted by juris335' post='887518' date='May 23 2009, 11:05 AM
Ah yes, another successful venture into the world of aftermarket rims.
+1
I have not owned every wheel available but after lots of misery I now use OEM or BBS only. NEVER any trouble.
Old 05-23-2009, 05:50 PM
  #25
CWS530's Avatar
Originally Posted by GENEaTALS' post='887722' date='May 23 2009, 03:16 PM
I believe the OP bought miro reps tho, those are one fo the few reps members tend to recc...
+1 Never heard about a problem with those. Can't say the same for most others.
Old 05-23-2009, 06:06 PM
  #26
forced528's Avatar
It's inconsistent and I am still tryin' to figure it out. But I am sensing that it may be the hub ring. I will call Miro when they open and see if they can help. I will keep my OEM's around just in case.
Old 05-23-2009, 11:43 PM
  #27
forced528's Avatar
Do any of current Miro M6 reps owners know what their whee's bore size is in mm? Also, can anyone confirm what the hub size is for our e60's?
I am trying to look for the 'right' hub centering rings for my car.
Thanks for your help.
Old 05-23-2009, 11:44 PM
  #28
Anzafin's Avatar
My Ride: Bmw 530d 2004
It's 72,56mm to be precise .
edit: And usually the most needed hub ring is 72,56mm / 74,1mm (which is the e39's hub bore size). My guess is that your Miro's hub is this e39 size.
Old 05-24-2009, 12:08 AM
  #29
E60714's Avatar
I was thinking about getting the M6 Miros at some point, but this thread kinda made it seem alot had to be done to make them actually work.
Is the only downside to buying OEM 167's that it's going to be really pricey? They say do it right the first time or do it again. But $2000+....
Old 05-24-2009, 03:44 AM
  #30
e60norway's Avatar
My Ride: E60 525d 2004
I had the exact same problem and thought it was the m5 replicawheels, but after much troubleshooting putting on OEM wheels and I still had the vibration I took the car to the dealer and it had nothing to do with my wheels. It was a worn out bushing in the middleshaft that was the cause and now its all ok.
So much for all of you OEM-wheel fanboys!
Quick Reply: Frustrated with new wheels
