front hub abs ring loose? causing abs/dsc errors
MOOG hub+wheel bearing assembly (513210) is $107 on RockAuto dot com.
FAG hub+wheel bearing assembly is $133 on AutohausAZ dot com.
Amazon has several [no-name brand parts] for cheaper.
Let me know if you find FAG/Lemforder/MOOG/Febi for cheaper.
My Ride: 530d
you have to remove the strut to remove the bearings, Thankfully undoing both lower arms is a relatively painless job and that provides room to drop the hub + strut enough to then remove the strut.
BrandonSS
03-13-2015 12:19 PM
