front fender replacement DIY ?
Hi,
I just had a yard tool fall from the ceiling and dent and scratch my drivers front fender on my 2010 528i. I want to just replace it with a new one. I did this on my daughters 2012 Nissan Murano and it turned out like new. But I had to remove the front bumper cover, the headlight, wheel covers etc. It was a project. I am hoping the bimmer will be a bit easier. Any directions out there? I can't find anything. I can tell the lower skirt will need to come off to access the lower screws. But not sure about the front bumper and headlight.
Thanks!
Ken
Thanks!
Ken
My Ride: 530i
Engine: M54
can you post a picture of the damage?
replacing a fender, while straightforward on an E60, is totally overkill unless the fender is damaged beyond repair. It is aluminum, so it takes a bit less to warrant replacement compared to a mild steel fender.
Agree, it's probably best to repair it unless totally destroyed. It has to be painted regardless and painting a small area and clearing the entire fender would most likely end in a better match. Either way, have someone who KNOWS what they are doing repair and paint this you will be much happier with the result.
My Ride: 530i
Engine: M54
the paint is black safire metallic. Its a 2010, garaged ,so matching should be easy. I have kept it waxed. The damage is right next to the hood, right on the crease. I can get a new alum fender painted and shipped around 300.00 and put it on myself. I have had the worst luck with body shops. Overspray, left off parts, trashing the interior, etc... paint peeling, you name it. When I replace parts it gets back together right with all the parts. I take my time.
beware of fitting pre-painted panels. depending on the paint manufacturer, black sapphire metallic can have three or more variances. maybe you get lucky and that pre-painted panel is the right variance. or, maybe not.
edit: got pics to load. that's totally repairable from what I see there. they'll want to blend into the hood.
Ken
