Front Bushings worn out
Bushings only cost 30 bucks each but the labor to replace them is a lot cause its a little pain to do the only problem with that is you don't really know if the ball joint is ok, plus if it's the first time changing them then thats ok, but if it's the second time then i would deff. replace the whole arm cause the area where the bushing gets pressed in and out stretches so the new one is going to be very loose in that spot. Change the whole arm and DIY cause its very easy.
UltimatePeter
DIY: Do It Yourself
09-28-2015 09:12 AM
TexaZ3
05-06-2015 09:54 AM
