Front brakes and new rotors?
The sensor does not have to be replaced. I'm on my fourth BMW (E28, E39, still have the E46, and the E60). I have replaced the pads and rotors on all four vehicles and have never replaced the sensors. You only NEED to replace the sensors under the following circumstances:
- You broke it when removing it
- You ran the brake pads down to the point where they came in contact with the sensor
- The cabling attached to the sensor is so old and brittle that it's about to break
Both my E28 and my E39 were over seven years old when I sold them, and they were still running on the original sensors.
My Ride: 2005 545i E60 Orient Blau Metallic
Premium, NAV, Winter Package, Heads Up Display, Logic 7 Audio, AngeliBright Upgrade [White], M5 Body Kit, M Embroidered Seats
Ive got 74K on my 05 545i and have had a number of brake jobs. On all occassions, the rotors were found to be within spec and did not require changing. Typically, the rotors need replacing every 100K or so. This depends on your pads but that's what my SA told me their practice is here. With this, my second pad and sensor change, the car bakes and behaves like new. Note that BMW changed the config on their rear sensor so that there is no longer an annoying squeak anymore, a problem that plagued me for the past 20K miles! Much better now. Leave the OEM rotors on unless absolutely necessary. My vehicle brakes perfect with this setup and has quite a few miles on it compared to the OP....
My Ride: Original E60 Spec:
530i - Silver Grey Out, Black Dakota Leather In, Navigation Pro, Voice Command, HiFi Audio, Sports Package, Premium Package, Cold Weather Package w/ Heated Seats, Style# 123 Alloy Track Wheels, Auto AC, Power Front Seats, Active Turn Xennon Headlights,
Mods:
OEM M-Tech Front Bumper, OEM M Side Skirts, OEM M5 Rear Bumper, M5 Trunk Lid Finisher, M5 Style Mirrors, Custom Hamann Style Splitter, Custom Hartge Style Diffuser, RD Sport Boot Spoiler, LCI Taillights, Bruce Miranda's V4 LCI Retro Cables, 6000K Xenon light Bulbs, Xenon White LED License Plate Lights, 8000K HID 9006 Fog Lights, Akalius� Front Headlight Euro Overlays, Matte Black Kidney Grilles, E60.Net Clings, Debadged, Llumar Tinting "Micro Edged, 15% Rear 35% Sides,
Engine Mods:
Custom Magnaflow Quad Exhaust w/ Eisenmann Stamped 3� Tips, RPI Scoop (Red)
Added Electronics:
V1 Equipped (Hardwired), OEM Alpine CD Changer Retrofit,
Shoes:
SOLD-20" Staggered Vertini Hennesey Rims, Falcon 452's Tires-SOLD
New Shoes:
19" VMR 710 Hyper Silver, General Exclaim UHP 245/35/19 Front-275/30/19 Rear, Gloss Silver Caliper Paint Job DIY
^_____________
Retired
______________
Took Delivery 10/26/2009: LOADED! E60 M5 Silverstone II/Black, Active Seats, Comfort Ventilated/Heated Seats, HUD, Brushed Aluminum Trim,
Originally Posted by Ricracing' post='694782' date='Oct 16 2008, 10:54 AM
The disk are changed every second time with the pads.
Sensors need renewal at every change.
Originally Posted by bespoke1' post='711884' date='Nov 4 2008, 09:33 AM
Is there a good DIY step by step somewhere for brake jobs??
http://www.bmwtips.com/tipsntricks/Changin...ngBrakePads.htm
Originally Posted by RobertB' post='712579' date='Nov 4 2008, 08:33 PM
It's what I wrote for E39's, but most of it still applies. I answered one of my own questions at the bottom - when replacing pads with factory pads, no shims required. When using aftermarket pads, I have had much less squeal when using shims.
http://forums.e60.net/index.php?autocom=ga...m&album=213
Originally Posted by GENEaTALS' post='712583' date='Nov 4 2008, 10:35 PM
The brake pad wear sensor must be replaced once it has
been removed (brake pad wear sensor loses its retention
capability in the brake pad).
I stand by what I said earlier about replacing the sensor, but this shows another reason why you would replace the sensor.
TexaZ3
05-06-2015 09:54 AM
