5Series.net - Forums
-   -   Front Arm Bushings (https://5series.net/forums/e60-discussion-2/front-arm-bushings-138474/)
skeematics Jun 9, 2014 04:42 AM
Front Arm Bushings
My bushings are shot and need replacing. Should i replace with OEM or use other brands that are less expensive? Is there a difference in performance?
Quarta2six Jun 9, 2014 08:19 AM
OEM is a little expensive.. LEMFORDER is just as good as OEM but will save you a couple bucs. Some people us MEHLE also.
audiophool Jun 9, 2014 04:26 PM
If there were an option for non-fluid type at the expense of a slightly stiffer ride, I'd be open to that. Back in the E34 days, you could put bushes off a 750 if you wanted them slightly stiffer than stock, or M5 if you were a little full-goose-bozo. I liked the way the M5 rode.
txag_530i Jun 10, 2014 02:51 PM
Meyle is a good brand, as is Febi.
