Front aand rear M sport bumpers onto an SE
My Ride: 535D Tourer - Pre LCI
Right guys, finally got both my front and rear M sport bumpers..... the only thing is one of the PDC holder on the F bumper is missing so i'll have to ring around the breakers for one....
I need to get the grills bought for the front, i have this list in mind, am i missing anything to enable me to fit - brackets etc?
Fog light covers (can use my SE fog lights can't i?)
Main lower centre grill
two ancillary grills that attach to the centre grill
left and right brake ducts
left and right headlight washer covers and brackets (3 pieces)
Number plate surround
I figure i can use my current kidney grills, seals, fogs and headlight washer base units - front bumper already has tow hook cover - i know i'll need to dremel my arches and shorten my undertray
RealOEM.com * BMW E61 535d M Trim panel, bumper, front(SA715)
Any help very welcome
Did you get a used bumper? Curious why one of the PDC holders would be missing. If I'm not mistaken, the brackets are welded on the inside. If you got it new one, I would be returning it. If used, how will you plan to fix it?
Hi Tony
The bumper is a used item, pristine condition apart from this piece missing.
My plan is to source one from a scrap car, its only a square piece which can be plastic welded by my bodyshop..... no massive issue
thanks Cosmin ![Wink](https://5series.net/forums/images/smilies/imported/wink.gif)
I've managed to find this guide https://5series.net/forums/topic/666...bumper-change/
I'm pretty certain that the previous guides (that I cant find for the life of me) didn't have any additional brackets like the ones mentioned here.
I just want to be able to place my order and have everything i need
Ah ok, makes sense now. Hopefully they have a ultrasonic welder and not a hot plate welder. The ultrasonic if used correctly won't transefer to the A surface. The hot plate most likey will, but you could always correct it and then repaint. Just don't let them use glue on it...!
No idea to be fair mate but thanks for the tips..... i thought if the chap didnt have any of these then silicone would be as good as anything.... the holder itself has a large area square plate for which to stick it to the bumper, therefore what ever i use, it'll have plenty of surface area to connect it to the skin...
Sounds back street but if it does the job
Thanks for all the helps guys ![Big Grin](https://5series.net/forums/images/smilies/imported/biggrin.gif)
I'll have to 'wing' it and post a full guide so that nobody elese gets stuck with this issue again
http://www.sawmillcreek.org/showthre...-polypropylene
kane1111
04-10-2015 04:40 PM
