Forgestar Wheels Front 19x9 Rear 19x10 Offset +35 Front and Back
Old Aug 26, 2010 | 04:36 PM
sachal007's Avatar
My Ride: BMW E-60 530I
like the title say, would these offset work for e60 non m5
I know i need spacers all around, but what MM? and is 9inch wide wheel in the front possible?
thanks in advance
Old Aug 26, 2010 | 04:45 PM
PraiseTheLowered's Avatar
9 inch front with a +35 offset? jeez good luck with that id say run a 20mm spacer in the front and a 25mm spacer in the back
9 is certainly possible, but the high offset makes it a problem
i am running 20x9.5 et16 with a 5mm spacer making it et11 my wheels cleared without it no problem but that was because of the low offset to begin with and the outer barrel
Old Aug 26, 2010 | 07:31 PM
bavarianXsales's Avatar
I suggest a 15mm on the front making it an ET20 & a 10mm on the rear making them an ET25. We have used those offsets on the E60 with those width wheels without any issue. I also suggest that you double check that the center bore of the wheels are 72.6. If they are, you can purchase a wheel spacer without any difficulty. If the center bore of the wheels are not 72.6, then you have 2 options. #1 - If a hub ring is available, you can use that on the wheel with the spacer that you purchase, or #2 - You will have to have custom spacers made that are hubcentric to what ever center bore the Forgestar wheel is & also to your car.
Kasmo
May 7, 2019 03:30 AM
kongse
Jul 17, 2015 03:29 PM
boyhamdzui
Apr 14, 2015 04:47 PM
SURYOYO
Sep 30, 2003 02:20 PM
