Fog lights fuse ????
My Ride: 530i
Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
Originally Posted by myfootsmells' post='747774' date='Dec 18 2008, 04:47 PM
5,6,19
Though I'd guess it's either 5 or 6 by the 50 AMP
I searched before whose installed the HID fog lights might need to change that fuse from 5A/7.5A to 25A, If mine is already 50A, Is it need to change to 60A ?
My Ride: 14 550i
is the fuse broken?
Originally Posted by ricky1329' post='747775' date='Dec 18 2008, 12:52 AM
Position 19 is empty.
My Ride: 530i
Originally Posted by myfootsmells' post='747779' date='Dec 18 2008, 05:23 PM
is the fuse broken?
My Ride: 530i
Originally Posted by ricky1329' post='747781' date='Dec 18 2008, 05:29 PM
Not fuse broken. Which is due to after installed the HID fog lights have flickering and some buddies advise need to change the fuse to fix this issue.
Originally Posted by ricky1329' post='747773' date='Dec 18 2008, 10:45 AM
Which one is the Fog light fuse ?
http://www.realoem.com/bmw/partgrp.do?mode...hg=63&fg=15
uhh fuse to fix flickering? Highly doubt that will solve your problem! what you need is a flicker harness to cancel the flickering or new ballasts that support anti flickering. wow that sounded really redundant...
My Ride: G30 M550i
Model Year: 2018
Clearly the fuse won't fix the flickering and, more importantly, never install a higher amp fuse in a circuit that isn't designed to handle the load!
schulrog is likely correct that you need some electronics to stop the flicker. If you haven't already, there are a ton of threads in the Parts, Accessories, and Mods section that deal with replacing fog lights and how to deal with the various issues surrounding this mod...
