Fluid filter power steering
My Ride: BMW 530i Engine M54
Hello.I'm from Russia.I propose to set the filter fluid power steering.In my E60 tank is the filter mesh.The old models of BMW and Mercedes was a tank with replaceable filter cartridge.It seems to me that the grid gets filtered.I found a solution - installed the tank with replaceable cartridge from an army vehicle.The result of filtering happy.This reservoir fit perfectly in a regular mount to my BMW!
What do you think?
[ATTACH][ATTACH][/ATTACH][/ATTACH][ATTACH][/ATTACH]
What do you think?
My Ride: 530i
Engine: M54
I like it! Nice work. I'll put the Alexander Ovechkin stamp of approval on it. did you get the tank for any particular model BMW or Mercedes?
Sounds like a plan to me. Don't see why that wouldn't work. The army truck filter/reseuave assembly is very close to the power steering reseuave on my old 1981 BMW e12, 528i with the replaceable filter. The e60 power steering reseuave has a filter permanently mounted inside, just not removable for replacement. When I serviced my system, several years ago, I replaced the reseuave with a new unit. Cost here in states was USD 65, cheep enough and 2 hose clamps plus fluid.
In my original tank is installed grid.It is bad filters and oil after replacing quickly darkens. In the filter with a replaceable cartridge filtering surface is much bigger and better filters.It will prolong the life of the pump and the steering rack.
My Ride: 2007 BMW 550i
nice nice, i'm guessing this isn't applicable to ARS equipped vehicles though. PS fluid reservoir is huge in those, maybe a special type of filter for the CHF oil? thought i doubt it.
