FLOOD in my battery compartment !!
Old 09-07-2011, 01:13 PM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Originally Posted by Gilgorm
My 2008 535i vent seems to be a different version. Maybe you should try a newer type or turn around the one that is there now. Although I can't imagine why any previous owner would flip it around in the first place.
Either way the vent faces, probably won't make any difference since It doesn't sound right that water is filling the outside panel so high that water enters the vent in the first place. Something is blocked or damaged.
GL
It did make a difference. When you install the vent the correct way as shown in your photo, it is very tight to snap all 6 clips around the vent to the body panel. If the vent is installed the wrong way as shown in my early post, it was very lose. You are also right about why water going into the quarter panel in the first place. I need to wait for rain to stop then I could remove the taillight assembly to see what is going on around that area.
Thanks,
Old 09-07-2011, 01:14 PM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Originally Posted by skylineseason
My car has the same problem. There is one drain hole in my car, but you have to remove the plaster cap from the bottom of the battery compartment.
Thanks for the tip. There are a few caps in the bottom of the battery compartment, which one should I remove ? Can you post a picture to show the correct plaster cap ?
Thanks,
Old 09-07-2011, 04:58 PM
530inOK's Avatar
My Ride: 540i
Model Year: 2017
Originally Posted by lcc014
I would like to do that but can you give a bit more details about the location of the drain holes in the sunroof ?
Thanks,
Not sure where the rear drains are. I have poured water in the sunroof channel and see it drip from in front and behind the rear tires. The front drains are easy to see.
In the sunroof the drains are in the corners (circle) and exit in the door jambs (arrow) behind the wiring boot.
Attached Thumbnails FLOOD in my battery compartment !!-sunroof.jpg   FLOOD in my battery compartment !!-sunroof_drain.jpg   FLOOD in my battery compartment !!-drain.jpg
Old 09-07-2011, 05:01 PM
ProMed's Avatar
My Ride: 535i
Thanks,
http://www.bimmerfest.com/forums/sho...d.php?t=259095
Old 09-07-2011, 06:24 PM
wolf's Avatar
My Ride: 2007 550i Jet Black|Black Options: Sport|Premium|Cold Weather|PDC|Nav|Satellite Radio|Active Steering|Convenience Entry Mods: Trinity Side Skirts|Trinity Black Grilles|LCI Tail Lights with Bruce V6|Fog Light Bezel Rings|MTEC V2 Angel Eyes|LED License Plate Lights
Originally Posted by balbs
Check the drain holes in the sunroof to make sure they are not clogged.
+1 there is a known problem with the sun roof drain hoses. When they get clogged water can get inside the roof and run down into the areas around the trunk shorting out PDC and other components - there is an easy test to check if they are clogged. Also, the dealers offer a service to "clean" the hoses. I just had this problem and water was coming in through my roof.
Old 09-07-2011, 09:53 PM
skylineseason's Avatar
My Ride: 2004 530i
The left one in the picture..
Thanks,
Old 09-08-2011, 09:05 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Thanks for the picture. Did you remove the cap from inside battery compartment or outside under the passenger side rear wheel ?
Old 09-08-2011, 09:07 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Excellent pictures to show the sunroof drain holes location. I will take a look this evening as rain starting to end soon in Boston.
Thanks,
Old 09-08-2011, 11:39 AM
My Ride: 2004 530i
From the outside. Just use a flat screw driver.
Old 09-08-2011, 03:34 PM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Great, many thanks....
Vman33
03-14-2022 04:43 AM
derooster
09-22-2016 07:30 AM
LandRange
10-05-2015 08:47 AM
lcc014
DIY: Do It Yourself
09-10-2015 05:57 AM
LandRange
09-06-2015 10:39 AM
Quick Reply: FLOOD in my battery compartment !!
