Why am I getting this warning? What can I do about it? |
did you install TPM's ? Did you reset the TPM on the I drive ?
oh man I have no clue whats TPM?
Tire Pressue Monitor , read you manual , it's very simple to reset via i drive
Good luck |
Good luck thank you, but do i have install something? |
You'll be good to go !! Mr 166 !!! :D :lol: :P |
If you have an older model e60 you don't have tpms you have ftm, and with the ftm you just have to go to idrive and reinitialize the flat tire monitor. later model e60's use tpms which is an actual pressure monitor attached to your valve stem inside the tire, early model e60's use the abs system do detect a change in whell rotation then notifies you that you have a flat.
Check your valve stems. The TPMS have a metal ones
DO THIS BEFORE RESETTING YOUR FTM
DO THIS BEFORE RESETTING YOUR FTM Check your tire pressure and make sure you DONT ACTUALLY HAVE A LEAK!!! I have mine at 40 psi cold. Once you have 40 psi in all 4 tires then reset the FTM and see if it still throws an error after a day or so. Michael
| All times are GMT -8. The time now is 07:38 AM. |
