Flat tire warning after installing 166
Old Aug 22, 2008 | 01:30 PM
Ellicit's Avatar
Why am I getting this warning?
What can I do about it?
Old Aug 22, 2008 | 01:32 PM
westcoast550's Avatar
did you install TPM's ? Did you reset the TPM on the I drive ?
Old Aug 22, 2008 | 01:35 PM
Ellicit's Avatar
oh man I have no clue whats TPM?
Old Aug 22, 2008 | 01:37 PM
Tire Pressue Monitor , read you manual , it's very simple to reset via i drive
Good luck
Old Aug 22, 2008 | 01:38 PM
Ellicit's Avatar
Good luck
thank you, but do i have install something?
Old Aug 22, 2008 | 01:39 PM
kieron's Avatar
I just went into the service bit on I Drive and pressed reset on the tyre warning message then turned iginition off and on a couple of times and it cleared itself.
Old Aug 22, 2008 | 01:40 PM
If the installer used your old stems it will be fine but the Idrive will throw a flat warning until you reset it .
You'll be good to go !! Mr 166 !!!
Old Aug 22, 2008 | 01:51 PM
cleung's Avatar
If you have an older model e60 you don't have tpms you have ftm, and with the ftm you just have to go to idrive and reinitialize the flat tire monitor. later model e60's use tpms which is an actual pressure monitor attached to your valve stem inside the tire, early model e60's use the abs system do detect a change in whell rotation then notifies you that you have a flat.
Old Aug 22, 2008 | 01:58 PM
dbae1978's Avatar
Check your valve stems. The TPMS have a metal ones
Old Aug 22, 2008 | 02:38 PM
acuteperformance's Avatar
My Ride: 14 550i
DO THIS BEFORE RESETTING YOUR FTM
Check your tire pressure and make sure you DONT ACTUALLY HAVE A LEAK!!! I have mine at 40 psi cold. Once you have 40 psi in all 4 tires then reset the FTM and see if it still throws an error after a day or so.
Michael
