Flat Tire Monitor
My Ride: 06 550i - Sport, CWP, Logic 7
Ok, so I've tried searching and now I'm really confused.
Flat Tire Monitor - no sensor in wheel (Typically 04-05 545i)
Tire Monitoring System - sensor in wheel
I have a 2006 550i sport with a build date of 1/2006. 3 of my valve caps are metal and one is a black plastic. Which system do I have??
Thanks
Thanks
My E60 530i does not work off the valves, it works off the ABS wheel speed sensors.When pressure is lost the rolling radius of the wheel is smaller ie more revolutions hence showing a fault.
My Ride: 2010 VW Passat Wagon 2.0l Tsi
Grey/Grey Budapest 18"
Lost to HPFP issues:
08 535i sport pkg
Lost to Dreaded E61 Sun roof leaks:
07 E61 530Xi
Depends on the year, but it is not the CAP, but the Valve stem it self If it is a longer Metal one you have the TPMS system and that would require a set of sensors if you get a second set of Wheels....
I think model year 06 is a tpm system that uses the ABS, but 07 -09 use the TPMS system. You might want to do a search on it. TPMS....
My 07 550 had the the FTM , my 08 has the TPMS............................you likely have the former.
My Ride: 2006 530i - Sport - 6spd - Orient Blue with Auburn/Anthracite
I'll chime in... I have a 2006 530i and it has the TPM system (no intelligence in the wheels - it watches the ABS sensor to determine if the wheel is changing RPM).
That's likely what you have, too.
Cheers!
Cheers!
My Ride: 2007 525i, mystic blue metallic, black leather interior, dark poplar wood trim, premium package, navigation, iPod, park distance control, voice activation, bluetooth.
Mods: Full M-Tech Kit, ACS Rep Rear Window Spoiler, ACS Rep Rear Deck Spoiler, ACS Rep Quad Diffuser, ACS Rep Exhaust Tips, Remus Duel Exhaust, De-badge, 20% Tint Front and Rear, Umnitza Predator Ice V2, HID fog lights, Clear Side Marker Light Bulbs (yellow when on), Dark Poplar Wood Shifter, Dark Poplar Wood e-Brake Handle, Dark Poplar Wood Steering Wheel Inserts, OEM Steel Pedals, OEM M Footrest, 19 inch OEM 121s (Summer), 18 inch 124s (Winter), Shadowline Window Trim, Blacked-out Kidney Grills
Just to confuse things....
My 2007 525i has TPM and the sensors.
![Blink](https://5series.net/forums/images/smilies/imported/blink.gif)
My 2007 525i has TPM and the sensors.![Blink](https://5series.net/forums/images/smilies/imported/blink.gif)
Originally Posted by DRANGED' post='661508' date='Sep 4 2008, 07:37 AM
Hmmm. ![Confused](https://5series.net/forums/images/smilies/confused.gif)
[quote name='jmdhuse' date='Sep 4 2008, 12:23 AM' post='661501']
Still confused.....no intelligence in the wheels = FTM (Flat Tire Monitor, ABS sensors)
TPMS = Tire Pressure Monitor System (sensors in the wheels....)
I'll just ask the dealer the next time I'm there....
