Flat Tire Display
![Talking](https://5series.net/forums/images/icons/icon10.gif)
Driving to work this morning, I heard the chime from the display monitor telling me I had a flat tire. Since I have run flats, I proceeded until I found a gas station where I was able to inpect my tires. I walked around my car, and each tire was fully inflated. Has anyone experienced a problem with their computer displaying the "flat tire" symbol, or any other symbol when nothing was wrong. Ocassionaly, the "tighten gas cap" icon also appears for no apparent reason.
Thanks.
Thanks.
Thanks.
Thanks.
Model Year: 2015
Engine: N55
1. You cannot detect a flat on RFT's by looking at them. The stiff sidewalls are designed to support even with no air in them, you must check them with a guage.
2. Yes the system does give false readings, it can be fixed with a software upgrade, contact your dealer if it happens again and the pressures are OK.
Banned
Thanks.
Thanks.
Thanks.
Thanks.
[/quote]
Indeed - my flat was from a nail causing a very slow leak... I was very impressed that the system picked it up and recommended to carry on driving as normal! (i.e. it knew the pressure had only dropped a little - I presume it would advise me again when more pressure was lost...) However, I was less than impressed with cost of replacement!
My Ride: Previous BMW's owned:
2012 X3
2011 335 cic
2010 535 Touring
2009 335 cic
2008 535 Touring
2007 535 Touring
2006 330cic
2005 330cic
2004 545i
2003 745i
2001 740i
1999 540i
1997 540i
1995 540i
1988 635i
1987 635i
1984 633i
1983 528e
Identical situation happened to me just yesterday. Visual inspection looked fine and when I checked with my trusty tire guage the tires were all within 2 lbs of each other; the lowest was 30#, the highest 32#.
So I went to my dealer; JMK Motors in Springfield NJ. The service advisor explained that the monitor system will notice the 2# difference and report it as a flat. He put proper air in all four tires and reset it and I was on my way.
Great job as usual JMK.
My Ride: '04 545iS 6 spd, bought new via eBay, 11/05; Blk/Gry, Cold, L7, PDC, BMW Rear seatcover for pets.
First "Bumwa" was a new 1971 2002. High performance 5s since 1987. Beamer motorcycles too, currently on an 07 BMW K1200 GT; also a Moto Guzzi 1000 SP III.
Originally Posted by bdav' post='223935' date='Jan 13 2006, 05:57 PM
Is the car meant to vibrate when the tire is flat? Mine had a flat rear nearside (runflat), which made the whole car shudder - its been replaced now, ut is this normal for the runflats?
This is another reason that I hate thumpflats; they are so damned rigid, you need a gauge to tell you that they are flat, after the "warning" system tells you....something. And no, don't be so sure that you can get even a tread puncture fixed...stand by for $325 bill.
Thriving on balloon snows,
Ray Hull
