flash-to-pass lamp adjustment?
Old Nov 28, 2009 | 08:53 PM
vkhong's Avatar
Model Year: 2010
I have adaptive Bi-Xenon and am familiar with the white screws for vertical and lateral adjustments. I just noticed tonight that my flash-to-pass lamps are uneven. The driver side light beam is higher than the passenger side. Is separate vertical adjustment possible for the flash-to-pass beam?
Old Nov 30, 2009 | 03:11 PM
vkhong's Avatar
Model Year: 2010
My Adaptive Bi-Xenons are aimed correctly as far as I can tell, both high and low beam. The H7 bulbs for flash-to-pass are seated firmly in their sockets. The flash-to-pass beam is still higher on the driver-side than the passenger-side. The theory on other BMW boards is that the driver-side flash-to-pass beam is higher for two reasons:
1) Prevent driver-side beam from blinding oncoming drivers
2) Catch the attention of a truck /bus driver in front of you via their side view mirror
Can you guys with Bi-Xenons check your flash-to-pass beams?
1) Park about 15 feet back from a wall / garage door
2) Engine on
3) Rotary light switch in the Park position (not On or Auto)
4) Pull your light switch lever towards you
Does your driver-side beam aim higher than the passenger-side beam?
Thanks for reading.
Old Dec 8, 2009 | 10:46 AM
djdc78's Avatar
my driver's side is higher for all the light settings, headlights, flash-to-pass, and high beams. I have Adaptive Bi-Xenons also. Is this the way it's supposed to be, or do i need to get them adjusted? Let me know what you come up with. Thanks.
DC
2) Engine on
Thanks for reading.
Old Dec 8, 2009 | 11:39 AM
Euronuts's Avatar
My Ride: 2006 550i
2) Engine on
Thanks for reading.
Yes and make sure you are on level ground as it will effect your light beam!!!
Vman33
Mar 14, 2022 04:43 AM
vince_e60
May 26, 2018 10:02 PM
bestofthebest
Jan 5, 2016 07:47 PM
DetailersDomain
Detailing Forum
Sep 22, 2015 03:59 PM
Bounce
Aug 31, 2015 10:04 AM
