FINALLY INSTALLED M5tech kit and too many problems now
My Ride: 2006 530xi w m5 tech kit, 2007 Mercedes e63 AMG, 2005 ford expedition
Ok Bmw enthusiast. Need some advice and some help. I started to install the front bumper on my 2006 530xi and first thing that went wrong was I broke one of the pdc senSors by pushing it out. Called dealer they want 220$ for one. Completely crazy!! So then I continue with the install but can't get the bumper to fit from wing to wing. I tried cutting down the foam in certain spots but nothing. The only way I can make it fit from end to end is by removing the complete foam. I'm pretty sure this is not correct. But I left it like that since I have to go back there to replace damaged pdc. Then I proceeded installing the side skirts no reall issue there but stupid clips were a pain in the ass. So I go and turn on the car first i get the annoying sound from the defaulty pdc then shortly after I start to here my fan start to go off and on. Now mind u I just replaced my waterpump and thermostat about 2 months ago. The fan stays on for about 10 seconds then turns off then starts back up in 40 seconds. So I decide to go into the hidden menu to see the temperature and idling in the driveway it sat with the fan coming on and off at 79-80c. So I'm starting to wonder is it possible I mite of hit a wire or something when placing fron bumper or pdc malfuction triggering other things to go haywire? The BMW service tech guy on the phone told me it was going to start to do odd things. So what u guys think? This definitely put a damper in what should of been a good day
So here's a recap- I know have non working pdc that gives out a ringing noise Even if I shut it off by hitting pdc button I still here it. I have a bumper that's just a tap away from probably breaking if someone backs into. Since there's no support (foam) behind it and now cant drive it since I'm not sure if I'm overheating! Good thing I'm on vacation as of this weekend. Get my mind of it. Lol
The sensor brackets do not or should not hold the sensor that tight. I'm curious if you have the correct sensor bracket. The LCI brackets are smaller... Even with the brackets being non oem, I still can't imagine they are that tight to the sensor. The other styro pad is in the attachment. If your fitment looks ok without the pad I personally would leave it off and go order the correct one. I can't recall exactly, but it seems as if I had to trim maybe 10 mm or so off the lower edge of the styro pad, but again, I don't have pdc sensors. Looks like there are holes in the pad to receive them but if you are not getting the bumper in the correct position I could see the back of the sensor contacting the surface of the pad.
wow really? I haw a smal gap I was goihg to do the placing washer trick to lessen the gap How unsafe is it running with out the bumper foam? Also I've been driving the car today really haven't notice the fan coming on much. Car was between 75c and 85c. I hit 100 to 105c on the freeway a couple of times doing 80 mph with the air on. But it didn't stay in the 100s for long. Am guesibg this is normal operating temperature? Thanks
the styro pad does a couple of things. Like, filling the void between the bumper support and skin. Without it, if something hits this area you could end up with a badly damaged bumper and it might not take much. The other thing, believe it or not is crash testing. There's several places in the car where this material is added for that purpose. I'm often wondering how this pad could help you. But in the end it's all about compliance when getting into things like this. You should order the m5 pads before you leave so they are waiting on you when you return.
So the m5 pads are Definetly the way to go ? If so I'll def will order and just to double check. When u say pad u mean the foam piece I removed but I need the one from a m5? Thanks
