Fault Codes n53 Engine
My Ride: E60 Lci 530i
Engine: N53
the first 2 codes, dont worry about it. you didnt have the ignition on when you read the codes?
rest of the codes, the valve one i dont know. but the other could be your NOx sensor that needs replacing
can you tell us a bit more about the car? model/year maintanance done?
only after I got the code for the Egr valve the rough I idle started. And it’s really bad like the whole car is shaking and like it’s almost dying. But don’t get any engine light or loss of power only the idle problem. Was at the shop today told me it had to reset the adaptions will drive and after work if it gets better. I had the code 30E9 to begin with but after reading a forum people said to just encode a new catalytic converter and the code was gone soon after the nox codes began and after that the egr and rough idle
