Fault codes could use others thoughts on this!
Old Jul 25, 2020 | 12:19 PM
Flguy76's Avatar
My Ride: 2004 BMW 530i, 2010 535, 2010 535xi
Default Fault codes could use others thoughts on this!
I had no fault codes but shift issues so i replace all the seals, sleeves etc under the mechatronix, since doing that bout 100 miles ago its been fine, today i got on it pretty hard and got these codes.. is there a transmission i can put in that wont break when i sneeze.. also i have to drive about 20 miles tomorrow morning, think ill be ok?
#4 valve but also says could be the damn plug i had a hard time getting in
Engine codes
Ofcourse this ugly message,
Old Jul 27, 2020 | 11:22 PM
donpb's Avatar
My Ride: '06 530i N52
If your car detects anything major, it'll go into limp mode to protect the engine but could also leave you stranded though.
Old Jul 28, 2020 | 02:21 PM
Flguy76's Avatar
This car is more sensitive than a teenage girl. I swear before this i had a 2010 caddy cts, even more options and i beat the heack out of that thing for 160k miles. Damn i want that car back.. This shit is nuts worrying if im going to break this princess of a whip... smdh
Old Jul 28, 2020 | 04:06 PM
donpb's Avatar
If you think that's bad, Lamborghinis are much worse.
Old Jul 29, 2020 | 02:45 AM
Flguy76's Avatar
True, well for older ones... newer models are much more robust. Also they usually aren't daily use. This car is ment to be.
Old Jul 29, 2020 | 08:37 AM
scottalexander's Avatar
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
You say, This car is more sensitive than a teenage girl.
Its more like dating a woman that is a 10 (e.g. she's high maintenance and then proactive maintenance to avoid the high maintenance).
Old Jul 29, 2020 | 08:43 AM
Flguy76's Avatar
Haha good point. Still someone else has neglected some proactive maintenance.. im at 90k this was the first fluid change shes had.... i believe im the only one to think protectively...
Old Jul 29, 2020 | 11:51 AM
donpb's Avatar
The only proactive maintenance that will work for that instance is either alcohol or hit it and quit it.
Old Jul 29, 2020 | 05:48 PM
Flguy76's Avatar
think i should have hit it and bailed..
Davese61
May 12, 2018 12:00 PM
luther99
May 9, 2013 04:59 AM
Shydee
Feb 29, 2012 10:42 PM
chris f
DIY: Do It Yourself
Nov 22, 2009 02:22 AM
monnot66
Nov 14, 2008 06:58 AM
