How Frequently Do You Add Oil?
Old 11-25-2012, 08:01 AM
Roy7's Avatar
My Ride: 2009 535i xDrive; Black Sapphire Metallic; Premium, Cold Weather Packages, Navi, PDC, 20% Solargard Tint
Default How Frequently Do You Add Oil?
So I've got a 2010 535xi with 53,000 miles. I had it serviced approximately 8,000 miles ago.
Now it says "need to add a maximum of 1 quart of oil".
Is something leaking or is that quart needed every 8,000 miles?
Thanks.
Old 11-25-2012, 08:13 AM
baveagle's Avatar
My Ride: 2008 535i2008 535i Monaco Blue PP, SP, SAT w/paddles, AS, CA, L7, NAV, PDC, Heated F Seats, SIRIUS, iPod+Aux, Bamboo Anthracite Wood Trim
Do you see leaks? Anyway, after 8,000 miles just change the oil and filter and be done with it.
Old 11-25-2012, 09:44 AM
Persian_535i's Avatar
Typical with these turbo engines, you should be changing your oil every 7500 miles anyway not 15k like bmw says.
Old 11-26-2012, 09:00 AM
brockallentaylor's Avatar
My Ride: 2006 530I Sport
That's no BS right there. Especially if you are tuned 7500 miles max!
Old 11-26-2012, 10:22 AM
dingolfing's Avatar
My Ride: 2008 550i
My 550 used up more synthetic when it was filled with the OEM oil, about a quart and a half in 10K miles. I switched to my trusted Mobil 1 this time around and am on pace to only use 1/2 to 1 quart in the same mileage window.
Old 11-26-2012, 10:37 AM
xoeightx's Avatar
I have a 06 530i with N52 motor. I just had to fill it up with 1 qt. of oil the other day. It has about 65K miles on it and I had a oil change about 2-3K miles ago. I plan to change my oil at 70K miles so about every 7.5K miles. I was thinking if I should change my oil to 10-30w since it seems to be burning oil quite fast. Any suggestion if this is a good idea or not and if your N52 motor is burning oil that fast too?
Old 11-26-2012, 11:32 AM
tonyb635's Avatar
I will get the warning around 1000 miles before its due if I wait. I got into the habit of changing it mid point and I never get the warning now. When I check it at that time, it looks to be just a little away from the max point on the scale.
Old 11-26-2012, 01:12 PM
srschang's Avatar
I have a 2008 528xi with 96,000 miles, I've had it since it had 9,000 miles. I change the oil when the car calls for it, usually 15-19,000 miles. I have to add 1 quart between oil changes. I'm crazy about keeping the engine leak free, so it's not from leaks.
Scott
Old 11-26-2012, 05:50 PM
19K Miles for an oil change holy ish that's bad!
Old 11-27-2012, 06:20 AM
BEE M's Avatar
I agree with the guy above me... 19k miles for an oil change?!?!?
Quick Reply: How Frequently Do You Add Oil?
