Eyebrows on with DRL's?
Old Jan 18, 2011 | 03:05 AM
kreveta's Avatar
Whenever daylight running lamps (high output bulbs in angel eyes) are on, eyebrows are always OFF. Would it be possible to have eyebrows on with DRL's without wiring? Maybe via NCS?
For those who don't know, DRL's light up in mode 3 (auto) and 0 (off), when DRL's are enabled in iDrive.
Thanks.
Old Jan 18, 2011 | 08:07 AM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Not possible via coding from what I have seen.
Old Jan 18, 2011 | 08:58 AM
kreveta's Avatar
How about wiring then?
Maybe making a simple Y-cable from DRL's to eyebrows too with some resistors? I guess eyebrows are 12V?
There's a NCS option to force "side makers" to be always on. Aren't side markers the eyebrows?
Old Jan 18, 2011 | 09:37 AM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Side marker is your side marker.
Yes it's possible to manually wire it. Rather simple actually, and resistors are not needed. Eyebrows are 12v, it says so right there on the plug.
Old Jan 18, 2011 | 09:44 AM
TheRacerBoss's Avatar
My Ride: Bmw
I thought the DRL's run below 12 volt
Also,
If you use a power meter you will find they have alternating current. Its that way atleast in my lexus.
Are you sure you can wire a drl into a eyebrow ????????????
Old Jan 18, 2011 | 09:57 AM
kreveta's Avatar
DRL's should be 12V (they produce at least 3 times more light output than standard angel eyes - parking angels).
If Eyebrows are 12V too then it should be really simple.
Alternating current is getting me confused though. Are you sure it's alternating in your Lexus? Maybe it's just not stable enough?
Old Jan 18, 2011 | 10:41 AM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Also,
Might be so on LCI's, but I vaguely remember that it can be coded to be on full power via NCSExpert.
I have enabled eyebrows as DRL and been running it for months now.
Old Jan 18, 2011 | 11:29 PM
Neroht's Avatar
My Ride: Type 523I UL (EUR) Dev. series E60 () Line 5 Body type LIM Steering LL Door count 4 Engine N52 Cubical capacity 2.50 Power 130 Transmision HECK Gearbox MECH Colour TITANSILBER METALLIC (354) Upholstery LEDER DAKOTA/SCHWARZ (LCSW) Prod. date 2006-05-15 Order options No. Description 1CA SELECTION COP RELEVANT VEHICLES 2NP M LT/ALY W. DOUBLE SPOKE 135 M W.RUNFLA 235 TRAILER-HITCH WITH REMOVABLE HEAD 302 ALARM SYSTEM 337 M SPORTS PACKAGE 339 SATIN CHROME 4M3 INTERIOR TRIM.FINI. ALU. CUBE PURE 428 WARNING TRIANGLE 442 CUPHOLDER 465 THROUGH-LOAD SYSTEM 470 CHILD SEAT ISOFIX ATTACHMENT 481 SPORT SEATS F DRIVER/FRONT PASSENGER 494 SEAT HEATING F DRIVER/FRONT PASSENGER 502 ; HEADLIGHT WASHER SYSTEM 508 PARK DISTANCE CONTROL (PDC) 522 XENON LIGHT 534 AUTOMATIC AIR CONDITIONING 540 CRUISE CONTROL 698 AREA-CODE 2 704 M SPORT SUSPENSION 710 M LEATHER STEERING WHEEL 715 M AERODYNAMICS PACKAGE 775 INDIVIDUAL ROOF-LINING ANTHRACITE 8SA COUNTRY SPEC. RELEASE OF NAVIGATION 8SP COP CONTROL 842 COLD CLIMATE VERSION 850 ADD FUEL TANK FILLING FOR EXPORT 863 EUROPE/DEALER DIRECTORY 877 DELETION CROSS-OVER OPERATION 885 SWEDISH/OWNERS HANDBOOK/SERVICE BOOKLET 896 DAYTIME LIGHTS FUNCTION 9AA EXTERNAL SKIN PROTECTION Series options No. Description 216 SERVOTRONIC
My eyebrows is on with ae or drl no problem maybe a euro mode?/M
Old Jan 19, 2011 | 12:08 AM
kreveta's Avatar
Neroht: I'm in Europe, I have a euro-spec E60 too. Eyebrows are off when DRLs are on. Note that DRLs I am referring to on LCI are the same angel eyes, but with high light output - different light bulbs.
Old Jan 19, 2011 | 07:57 AM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
He might be setting it to parking lights.
As far as I know, by default eyebrows are off unless set to parking light or low beam is on. This is the same for pre and LCI.
